Affordable Unbreakable Connectivity
The UBR LTE provides an all-in-one WAN solution for industrial deployments with GE WAN, 4X GE LAN, and 2X LTE connectivity as well as Peplink’s SpeedFusion SD-WAN bonding technology.
1 x GE WAN Ports
4 x GE LAN Ports
2 x LTE Modems
SpeedFusion Bandwidth Bonding
Get it all with PrimeCare
Hardware Warranty
Software Upgrades
InControl2 Access
SpeedFusion
Straight out of the box, the UBR LTE provides unbreakable connectivity with PrimeCare, which includes SpeedFusion functionality, FusionHub licenses, and browser-based SD-WAN manage-ment with InControl.
Built to Last
DIN mounts and Molex power connectors let the UBR LTE integrates seamlessly with your existing equipment racks. In addition, the fanless, ruggedized chassis supports an extended operating temperature range.
Traffic Steering
Instantly recognize the application for each packet. Then apply different outbound policy, firewall rules, or even SpeedFusion technologies to the traffic depending on its application.
WAN Interface 1x GE
2x LTE Modems
SIM Card Size Mini-SIM (2FF) Redundant SIM Slots Yes LAN Interface 4x GE Wi-Fi Standards 2.4GHz: 802.11b/g/n OR 5GHz: 802.11a/n Antenna Connectors 4x SMA Cellular, 2x Wi-Fi, 1x SMA GPS Recommended Users 1-60 Router Throughput 120Mbps SpeedFusion Hot Failover Yes* SpeedFusion WAN Smoothing Yes* SpeedFusion Bandwidth Bonding Yes* Number of PepVPN SpeedFusion Peers 2/5 * SpeedFusion Throughput (No Encryption) 40Mbps SpeedFusion Throughput (256-bit AES) 20Mbps Power Input Device: 12V – 28V DC AC Adapter: AC Input 100V – 240V / DC Output 12V Terminal Block: 12V – 28V DC Power Consumption 24W (max.) Dimensions 5.1 x 4.3 x 1.6 inches | 130 x 110 x 41 mm
Weight 1.2 pounds / 515 grams Operating Temperature -40° – 149°F / -40° – 65°C
Certifications FCC, CE, RoHS, IC, E-mark
EN 61000: Electromagnetic Compatibility
Warranty 1-Year Limited Warranty *Requires PrimeCare Subscription, complementary for the first year.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web BlockingComplete VPN Solution PepVPN/SpeedFusion Hot Failover^
-Site-to-Site VPN
-Hot Failover
-256-bit AES Encryption
IPsec VPN (Network-to-Network)Global Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Advanced QoS Individual Bandwidth Limit
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMPCaptive Portal Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3^ Requires PrimeCare Subscription, complementary for the first year.
- UBR device
- 12V2A Power Supply
- 2x Wi-Fi Antennas (ACW-341)
- 4x 4G LTE Antennas (ACW-813) / 4x 4G LTE Antennas (US Version) (ACW-234)
- 1x GPS Antenna
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands UBR-LTE-E-T-PRM Europe/
International/
CAT-4
2 B1, B3, B5, B7, B8, B20, B38, B40, B41 WCDMA/HSPA+/DC-HSPA+: B1, B5, B8
UBR-LTE-MX-T-PRM Latin America/
Australia/ CAT-42 B1, B2, B3, B4, B5, B7, B8, B28, B40 WCDMA/HSPA+/DC-HSPA+:
B1, B2, B5, B8UBR-LTE-US-T-PRM America/
CAT-42 Cellular 1: B1, B2, B3, B4, B5, B7, B8, B12, B13, B20, B25, B26, B29, B30, B41 Cellular 2: B12, B14, B4, B2, B5, B13, B66, B71 Cellular 1: WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8 Cellular 2: B2, B4, B5
