Travel with SFC Cover
For when downtime is unacceptable
IoT with SpeedFusion
From smart TVs to security cameras to medical sensors, a stable connection has become a vital part of daily operations. It’s time to make sure your systems always stay up.
SpeedFusion Connect
Hot Failover ensures your connection never fails
Enjoy the open air as you work with zero network disruptions
Peplink eSIM Data Plans
No more worries about SIM management
Top up your eSIM data with just a few taps
Generate Network Reports
Get alerts on sudden connection drops
App UI
Remotely Monitor Your Network
Check up on the status of each device from afar
App UI
SFC App Section Background
Manage SpeedFusion on our companion app
SpeedFusion Connect App
Bring the easiness of network management to the palm of your hand
UI Image 1
Monitor Your Router
connection status and configure WAN usage
UI Image 2
Connect Your Router
to Peplink Cloud Locations in over 25 cities
UI Image 3
Active SpeedFusion Service
for connectivity protection
UI Image 4
View Reports
on WAN quality and data usage
UI Image 5
Share Access
with friends and family to manage your devices
UI Image 6
Manage Multiple Routers
at the same time
