Stay connected wherever you go
Travel with SpeedFusion
No matter where you go, a reliable internet connection is a constant requirement. Though a single cellular hotspot might be enough for excursions close to cities, it won’t be enough if you go further out.
SpeedFusion Connect
Enjoy the open air as you work with zero network disruptions
Peplink eSIM Data Plans
Top up your eSIM data with just a few taps
Swap Your WANs Freely
Easily switch between your connections through our app
Application Priority Control
Prioritize certain network traffic so they don’t suffer any stutters
Manage SpeedFusion on our companion app
SpeedFusion Connect App
Monitor Your Router
connection status and configure WAN usage
Connect Your Router
to Peplink Cloud Locations in over 25 cities
Active SpeedFusion Service
for connectivity protection
View Reports
on WAN quality and data usage
Share Access
with friends and family to manage your devices
Manage Multiple Routers
at the same time
