SDX Pro
Modular SD-WAN Router with Edge Computing Capability
In addition to the power of the SDX, the SDX Pro offers greater flexibility and functionality. It has two FlexModule slots, enabling you to customize the device with different modules to suit any deployment. It supports edge computing so it can deliver websites, applications, and docker containers to connected devices.
Compatible With:
Modular System. Ensure Flexibility
Future Proof Design
4G/5G cellular WAN
Add 4G/5G backup to enterprise networks. Add multiple cellular FlexModules for fast and unbreakable connectivity anywhere.
8x copper WAN/LAN
Connect PoE-enabled modems on the WAN, or connect PoE devices such as cameras, IP phones, and Wi-Fi APs on the LAN.
4x fiber WAN/LAN
Build an all-Fiber network by connecting Fiber WANs and LAN Switches.
56x SIM Capacity
Virtually deliver SIM cards from the FlexModule to Peplink cellular routers anywhere. Supports up to 56 SIM cards.
The SDX Pro has enough throughput to handle any
high-bandwidth enterprise branch or mobile deployment.
Ready-Built Infrastructure
Your SDX Pro comes ready to connect to the SpeedFusion Cloud: a global network of secure endpoints with unique capabilities. Use the SpeedFusion Cloud as an unbreakable worldwide VPN, saving setup and maintenance costs.
Edge Computing Capable
Websites
Virtual Machines
Docker Containers
Applications
The SDX Pro is a one-box hosting solution that can deliver Docker containers, applications, and websites to its local network. By hosting resources near the network edge, you can reduce latency and make applications more responsive.
Uninterruptible Power
The SDX Pro is equipped with two power inputs and two hot-swappable power supplies. Only one of each is needed to function, ensuring continuous power delivery even if a cable gets disconnected or if a power supply drops out for any reason.
* WAN ports are configured as a LAN ports by default, configuration is changeable on the Web Admin.
8x GE PoE Module (EXM-8C) ^ Interface 8x 10/100/1000M Ethernet Ports *
Capable of PoE+Power Consumption 15W (255W max. with 802.3at/af PoE+ Output) Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 1.1 pounds | 475 grams
* Module can be configured with LAN or WAN ports as needed.
# Antenna is not included.
4x SFP+ Module (EXM-4F) # Interface 4x SFP+ Ports * Power Consumption 11W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 0.83 pounds | 375 grams
SIM Injector FlexModule (EXM-SIM-BK56) # SIM Slot Capacity 56 4FF Nano SIM Cards Power Consumption 15W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 1.30 pounds | 600 grams Compatible with EPX, SDX Pro
3x LTE-A Module (EXM-3LTEA) # Interface 3x Embedded LTE-A Cellular Modems
with Redundant SIM Slots
Antenna Connectors 6x SMA Cellular Antenna Connectors
1x SMA GPS Antenna Connector
Downlink/Uplink Datarate 300Mbps/50Mbps (CAT-6)
600Mbps/150Mbps (CAT-12)
Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
CAT-12. 4x LTE-A Module (EXM-4LTEA) # Interface 4x Embedded LTE-A Cellular Modems
with Redundant 4FF Nano SIM SlotsAntenna Connectors 8x SMA Cellular Antenna Connectors
1x SMA GPS Antenna ConnectorDownlink/Uplink Datarate 600Mbps/150Mbps Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
CAT-20. 2x LTE-A Module (EXM-2GLTE) # Interface 2x Embedded LTE-A Cellular Modems
Downlink/Uplink Datarate 2Gbps/211Mbps Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
2x 5G Module (EXM-2X5G) # Interface 2x Embedded Cellular Modems
with Redundant 4FF nano SIM SlotsAntenna Connectors 8x SMA Cellular Antenna Connectors
1x SMA GPS Antenna ConnectorDownlink/Uplink Datarate 5G: 4 Gbps / 700 Mbps
LTE CAT-20: 2 Gbps / 150 MbpsPower Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
# Antenna is not included. -
Software Peplink Balance Firmware WAN Support for PPPoE, Static IP, DHCP
WAN Link Health Check
-PING
-DNS Lookup
-HTTP
Bandwidth Allowance Monitor
IPv6 Support
USB 4G/3G Modem Support
-changeip.com
-dyndns.org
-no-ip.org
-tzo.com
-DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
-Fastest Response TimeSecurity DoS Prevention
Stateful Firewall
Web Blocking
Site-to-Site VPN
-Bandwidth Bonding
-Hot Failover
-256-bit AES Encryption
-Dynamic Routing
PPTP/L2TP/OpenVPN Server
-X.509 Certificate Support
-Bandwidth Reservation
-Individual Bandwidth Limit
Application Prioritization
-By User Groups
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
BGP, OSPFv2 and RIPv2 Support
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Support RADIUS Authentication
Support LDAP Authentication
DNS Built-in Authoritative DNS
Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT records
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Power Requirements Universal Input 100V – 240V AC *Only valid for customers who have purchased Peplink Balance devices directly from Peplink.
- Balance SDX Pro
- SDX Pro Base Chassis
- 1U 19″ Rack-mount Chassis (ACW-752)
- L-mount Set (ACW-750)
- 2x Power Cord (ACW-614)
- Rubber Foot Pad set
- Balance SDX Pro
Product Code Carrier Modem 4G Bands 3G Bands EXM-3LTEA-W America/Europe/
CAT-6
3 B1, B2, B3, B4, B5, B7, B8 , B12,
B13, B20, B25, B26, B29, B30, B41
B1, B2, B3, B4, B5, B8 EXM-3LTEA-P Asia Pacific/
CAT-6
3 B1, B3, B5, B7, B8, B18, B19,
B21, B28, B38, B39, B40, B41
B1, B5, B6, B8, B9, B19, B39 EXM-3LTEA-R America /
FirstNet /
CAT-12
3 B1, B2, B3, B4, B5, B7, B8, B9,
B12, B13, B14, B18, B19, B20,
B26, B29, B30, B32, B41, B42,
B43, B46, B48, B66
B1, B2, B4, B5, B6, B8, B9, B19 EXM-4LTEA-D APAC & EMEA /
CAT-124 B1, B2, B3, B4, B5, B7, B8, B9,
B12,B13, B14, B17, B18, B19,
B20, B21,B25, B26, B28, B29,
B30, B32, B38, B39, B40, B41,
B66B1, B2, B3, B4,
B5, B8, B9, B19EXM-4LTEA-R America /
FirstNet /
CAT-12
B43, B46, B48, B66
B1, B2, B4, B5, B6, B8, B9, B19 EXM-4LTEA-Q APAC & EMEA /
CAT-124 B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B38, B39, B40, B41, B42, B43, B48, B66, B71 B1, B2, B4, B5, B6, B8, B9, B19 EXM-2GLTE-G Global /
CAT-18
2 B1, B3, B25(B2), B66(B4),
B26(B5/B18/B19), B7, B8,
B12(17), B13, B14 , B20, B28,
B29, B30, B32, B71, B38, B39,
B40, B41, B42, B43, B46, B48
B1, B2, B4, B5(B19), B8 EXM-2GLTE-S Global /
CAT-20
2 B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 B1, B2, B4, B5, B6, B8, B9, B19 Product Code Carrier Modems 5G Bands LTE Bands EXM-2X5GD APAC & EMEA
5G2 5G (NSA) Sub 6Ghz:
n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13,
B40, B41, B42, B46, B66, B71EXM-2X5GH North America
n1, n2, n3, n5, n28, n41, n66, n71,
B40, B41, B42, B46, B48, B66, B71EXM-2X5GN APAC & EMEA
5G2 5G (SA&NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 -
Product Code Description BPL-SDX-PRO-M2 SDX Pro Base Model, No Expansion module, 500GB SSD, 2x GE WAN/LAN Ports, 2x 10GE SFP+ WAN/LAN ports, 2x USB WAN BPL-SDX-PRO-M2-1TB SDX Pro Base Model, No Expansion module, 1TB SSD, 2x GE WAN/LAN Ports, 2x 10GE SFP+ WAN/LAN ports, 2x USB WAN BPL-SDX-PRO-M2-2TB SDX Pro Base Model, No Expansion module, 2TB SSD, 2x GE WAN/LAN Ports, 2x 10GE SFP+ WAN/LAN ports, 2x USB WAN Product Code Description EXM-8C Expansion Module with 8x GE PoE ports EXM-4F Expansion Module with 4x SFP+ ports EXM-SIM-BK56 Expansion Module with 56 SIM slots EXM-4LTEA-D Expansion Module with 4x LTE-A Pro modems (CAT-12) EXM-4LTEA-R Expansion Module with 4x LTE-A Pro modems (CAT-12) EXM-4LTEA-Q Expansion Module with 4x LTE-A Pro modems (CAT-12) EXM-2GLTE-S Expansion Module with 2x LTE-A Pro modems (CAT-20) EXM-2X5GD Expansion Module with 2x 5G modems EXM-2X5GH Expansion Module with 2x 5G modems EXM-2X5GN Expansion Module with 2x 5G modems -
Product Code Description LIC-VWAN Activate 1x Virtual WAN on Balance SDX Pro* LIC-2VWAN Activate 2x Virtual WAN on Balance SDX Pro* LIC-3VWAN Activate 3x Virtual WAN on Balance SDX Pro* LIC-OPN-WAN OpenVPN WAN License ECP-BPL-SDX-PRO-M2-1Y EssentialCare+ (1-Year) for Balance SDX Pro ECP-BPL-SDX-PRO-M2-2Y EssentialCare+ (2-Year) for Balance SDX Pro ECP-BPL-SDX-PRO-M2-4Y EssentialCare+ (4-Year) for Balance SDX Pro SVL-BPL-SDX-PRO-M2-1Y 1-Year EssentialCare for Balance SDX Pro SVL-BPL-SDX-PRO-M2-2Y 2-Year EssentialCare for Balance SDX Pro * Learn more about Virtual WAN Activation License here.
Case Studies
- Live X Discovers the X Factor in Peplink’s Devices
- Industrial IoT for Traditional Factories
- Mobile Clinic Connectivity
- No Loss. Scalable. Extreme Performance.
- Rockstar Show Services Rocks Unbreakable Connectivity for Video Production
- Manufacturing Plant Assembles Complete Peplink Infrastructure for Reliable Connectivity
- Cruising with Passion
- Student Dormitories House Reliable Connectivity Through an MSP
- MSP Retires MPLS Network for SD-WAN Setup
- SpeedFusion Disaster Recovery on Alarm Monitoring System
- Mobile Command Center for Protection & Rescue Zurich Locks In Secure Connectivity
- Do you have any suggestions for a 10G SFP transceiver?
Learn more about the recommended SFP transceiver at this post
