Balance 310X
DC Rugged anchor DC IP55 anchor
Affordable
High Performance
The Balance 310X uses all GE ports and offers a routing throughput of 2.5 Gbps. It provides all the connectivity needed to support small and medium sized business operations.
Unbreakable Connectivity with LTE
The Balance 310X provides built-in LTE for seamless failover. Patented SpeedFusion technology combines multiple connections for jitter-free calls and high-speed transfers.
Rugged Industrial-Grade Design
The Balance 310X has a fanless design and a wide temperature range. Drop it into demanding environments and run it for years without worry.
Scalable Management
The Balance 310X comes with the InControl central management system. Easily centralize firewall rules, outbound policy, VLAN, device configurations and more.
Specifications
 Balance 310X
WAN Interface2x USB Interface
2x GE
1x Embedded LTE-A Modem with Redundant SIM Slot
SpeedFusion Hot Failover
SpeedFusion WAN Smoothing
SpeedFusion Bandwidth Bonding
Number of PepVPN SpeedFusion Peers2/30^
LAN Interface9x GE
Router Throughput2.5 Gbps
PepVPN/SpeedFusion ThroughputNo Encryption: 600 Mbps
256-bit AES: 500 Mbps
LTE ModemLTE Advanced Pro CAT-12/ CAT-18
CAT 12: Downlink/Uplink Datarate:
600 Mbps/150 Mbps
CAT 18: Downlink/Uplink Datarate:
1.2 Gbps/150 Mbps
Recommended Users50-500
Cellular and GPS
Antenna Connector
2x SMA Antenna Connectors
(for CAT-12)
4x SMA Antenna Connectors
(for CAT-18)
1x SMA GPS Antenna Connector
Power InputPower Din DC: 12V - 30V
Power Consumption30W (max.)
Dimension
(W x D x H)
1.7 x 11.5 x 7.0 inches
43 x 292 x 177 mm
Weight7.28 pounds
3.3 kg
Operating Temperature-40° – 149°F
-40° – 65°C
CertificationsCE, FCC, RoHS
Warranty1-Year Limited Warranty
^ 2 SpeedFusion Peers are enabled by default. Can be increased to 30 Peers with purchase of SpeedFusion license SFN-LC-30.
Ordering Information
 Product CodeCarrierEmbedded Modem4G Bands3G Bands
LTE-A ProBPL-310X-
LTEA-R-T
America /
FirstNet /
CAT-12
1B1, B2, B3, B4, B5, B7, B8, B9, B12,
B13, B14 ,B18, B19, B20, B26, B29,
B30, B32, B41, B42, B43, B46, B48, B66
B1, B2, B4, B5, B6, B8, B9, B19
BPL-310X-
LTEA-K-T
Global* /
CAT-12
B13, B18, B19, B20, B26, B28 , B29,
BPL-310X-
GLTE-G-T
Global /
CAT-18
1B1, B3, B25(B2), B66(B4),
B26(B5/B18/B19), B7, B8, B12(17),
B13,B14 , B20, B28 , B29, B30, B32,
B71, B38,B39, B40, B41, B42, B43,
B46, B48
B1, B2, B4, B5(B19), B8
* China & HK TD LTE are excluded.
Feature Add-On
Product CodeProduct NameDescription
SFN-LC-30SpeedFusion Bonding
License Key for Balance 310X
Enable up to 30 SpeedFusion Bonding peers for Balance 310X
Technical Specifications
Security
  • DoS Prevention
  • Stateful Firewall
  • Web Blocking
  • Web Filtering Blacklist
Captive Portal
  • Support for Wired and Wireless LAN Clients
  • Support RADIUS Authentication
  • Time and Usage Quotas on Open Access Mode
  • Built-in Customizable Splash Page
Device Management
Power Requirements
  • Power Din DC: 12V – 30V
Package Content
  • Balance 310X
    • LTE Antenna x 2 (ACW-234)
    • GPS Antenna x 1 (ACW-232)
    • 24V 2.5A PSU x 1
    • L-Mount x 2
    • Power Cord x 1
  • Download Datasheet
    Go!
