Ultimate Performance for your Branch Office
                                    30 VPN Peers
                                    High Capacity. 500 Users
                                    2.5 Gbps Throughput
Unbreakable Connectivity with 5G
The Balance 310X provides built-in 5G for seamless failover. Patented SpeedFusion technology combines multiple connections for jitter-free calls and high-speed transfers.
FirstNet Ready
FirstNet (Band 14) provides first responders with a specialized 5G network with more priority and network capacity. The Balance 310X supports Band 14, providing additional coverage as the situation demands.
Rugged Industrial-Grade Design
The Balance 310X has a fanless design and a wide temperature range. Drop it into demanding environments and run it for years without worry.
Scalable Cloud Management
The Balance 310X comes with the InControl central management system. Easily centralize firewall rules, outbound policy, VLAN, device configurations and more.
#PowerofPeplink
Experience on-demand connectivity with SpeedFusion Connect
Enabling the benefits of SpeedFusion has just gotten easier with SpeedFusion Connect. Allowing you to leverage the LTE of multiple connections and SpeedFusion technologies all under one subscription. Enabling backup connectivity has never been so simple!
*Compatible for use in the US and selected regions in Europe
 WAN Link Health Check
 -PING
 -IPv6 Support
 -DNS Lookup
 -HTTP
 Bandwidth Allowance Monitor
 USB 4G/3G Modem Support
 Intelligent Failover
 -changeip.com
 -dyndns.org
 -no-ip.org
 -tzo.com
 -DNS-O-MaticLAN DHCP Server for LAN Clients
 Extended DHCP Option
 DHCP Reservation
 DNS Proxy for LAN Clients
 VLAN on LAN Support
 Session Persistence
 Per-Service Load Distribution
 Multiple Algorithms
 -Weighted
 -Enforced
 -Persistence
 -Priority
 -Overflow
 -Least Used
 -Lowest Latency
 -Fastest Response Time
 Security DoS Prevention
 Stateful Firewall
 Web Blocking
 Web Filtering Blacklist
 Site-to-Site VPN
 -Bandwidth Bonding
 -Hot Failover
 -256-bit AES Encryption
 -Dynamic Routing
 PPTP/L2TP/OpenVPN Server
 -Local User Active Directory Authentication
 -X.509 Certificate Support
 -Bandwidth Reservation
 -Individual Bandwidth Limit
 Application Prioritization
 -By User Groups
 -SIP, HTTPS, VPN QoS
 -Custom Application QoS
 Static Routes
 Port Forwarding
 Many to One, One to One NAT
 NAT Pool
 SIP ALG, H.323 ALG
 UPnP, NAT-PMP
 WINS Server
 VRRP HA Support
 BGP, OSPFv2 and RIPv2 SupportAP Controller Support for Pepwave AP Series
 Auto AP Discovery
 Auto AP Firmware Management
 AP Profile Configuration
 Wi-Fi Usage Statistics
 Support RADIUS Authentication
 Support LDAP Authentication
 DNS Built-in Authoritative DNS
 Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT records
 Command Line Interface
 InControl Cloud Management
 Email Notification
 Active Client & Session Lists
 Bandwidth Usage Statistics
 Syslog Service
 SNMP v1, v2c and v3
    Product Code Carrier Embedded Modem 4G Bands 3G Bands BPL-310X-
 LTEA-R-T
 America /
 FirstNet /
 CAT-12
 1 B1, B2, B3, B4, B5, B7, B8, B9, B12,
 B13, B14 ,B18, B19, B20, B26, B29,
 B30, B32, B41, B42, B43, B46, B48, B66
 B1, B2, B4, B5, B6, B8, B9, B19 BPL-310X-
 LTEA-D-T
 Global /
 CAT-12
 B13, B14, B17, B18, B19, B20, B21,
 B25, B26, B28, B29, B30, B32, B38,
 B39, B40, B41, B66
 BPL-310X-
 LTEA-K-TGlobal /
 CAT-121 B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
 B18, B19, B20, B26, B28, B29, B30, B32,
 B41, B42, B43, B46, B48, B66HSPA+: B1, B2, B4, B5, B6, B8, B9, B19 BPL-310X-
 GLTE-S-T
 Global /
 FirstNet /
 CAT-20
 1 B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
 B30, B32, B34, B38, B39, B40, B41, B42,
 B46 (LAA), B48, B66, B71HSPA+/WCDMA: B1, B2, B3, B4, B5, B6, B8, B9, B19 EXM-310X-
 GLTE-S *Global /
 CAT-201 B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
 B46 (LAA), B48, B66, B71HSPA+/WCDMA: B1, B2, B3, B4, B5, B6, B8, B9, B19 *Expansion Module for B310X with 1x LTE-A Pro (CAT-20) modem
    Product Code Embedded Modem(s) Region 5G Bands LTE Bands BPL-310X-5GD-T 1x 5G Global 5G (NSA) Sub 6Ghz:
 n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13,
 B40, B41, B42, B46, B48, B66, B71BPL-310X-5GH-T 1x 5G Global^ 5G (NSA) Sub 6Ghz:
 n1, n2, n3, n5, n7, n8, n12, n20, n25,
 n28, n38, n40, n41, n66, n71, n77,
 B40, B41, B42, B46, B48, B66, B71BPL-310X-5GN-T 1x 5G Global 5G (NSA & SA)) Sub 6Ghz:
 n1, n2, n3, n5, n7, n8, n12, n13, n14,
 n18, n20, n25, n26, n28, n29, n30,
 n38, n40, n41, n48, n66, n70, n71,
 n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13,
 B28, B29, B30, B32,B34, B38, B39,
 B40, B41, B42, B46, B48, B66, B71EXM-310X-5GD * 1x 5G Global 5G (NSA) Sub 6Ghz:
 B14, B17,B18, B19, B20, B25, B26,
 B40, B41, B42, B46, B48, B66, B71EXM-310X-5GH 1x 5G Global# 5G (NSA) Sub 6Ghz:
 B40, B41, B42, B46, B48, B66, B71EXM-310X-5GN * 1x 5G Global
 B40, B41, B42, B46, B48, B66, B71*Expansion Module for B310X with 1x 5G modem ^US Carrier Certifications: AT&T, T-Mobile, US Cellular, Verizon # US Carrier Certifications (Pending)
    Product Code Product Name SFN-LC-50 Up to 50 SpeedFusion Peers License Key for Balance 310X SFN-LC-30 Up to 30 SpeedFusion Peers License Key for Balance 310X
 SVL-321 1-Year EssentialCare for Balance 310X LTEA SVL-923 2-Year EssentialCare for Balance 310X LTEA ECP-BPL-310X-LTEA-1Y EssentialCare+ (1-Year) for Balance 310X LTEA ECP-BPL-310X-LTEA-2Y EssentialCare+ (2-Year) for Balance 310X LTEA ECP-BPL-310X-LTEA-4Y EssentialCare+ (4-Year) for Balance 310X LTEA ECP-BPL-310X-5G-1Y EssentialCare+ (1-Year) for Balance 310X 5G ECP-BPL-310X-5G-2Y EssentialCare+ (2-Year) for Balance 310X 5G ECP-BPL-310X-5G-4Y EssentialCare+ (4-Year) for Balance 310X 5G SVL-BPL-310X-5G-1Y 1-Year EssentialCare for Balance 310X 5G SVL-BPL-310X-5G-2Y 2-Year EssentialCare for Balance 310X 5G LIC-VWAN Activate 1x Virtual WAN
 LIC-2VWAN Activate 2x Virtual WAN
 LIC-3VWAN Activate 3x Virtual WAN
    - Balance 310X
- 1x PSU 24V 2.5A (ACW-647)
- 2x or 4x LTE/5G Antennas (ACW-234)
- 1x GPS Antenna (ACW-232)
- Ear L-Mounts kit (ACW-513)
- Rubber Foot Pad Set
- Grounding Cable
    Balance 310X Datasheet
 Balance 310X 5G Datasheet
 User Manual
 FAQCase Studies - Work from Home
- Multimarine Shipyard Utilises Peplink’s Indoor and Outdoor Multi-WAN Solutions
- Agricultural Company Equips Farming Equipment with IoT and Peplink
- Local Police Force Secures Resilient Connectivity for Security Cameras
- Banknote Company Assembles DC-DRC Network with Peplink
- A Reliable Installation of Secure Branch Connectivity with an MSP
