MFA 750
Unbreakable Connectivity with Content Caching
The MFA 750 comes equipped with MediaFast, our supercharged content caching solution. Designed with education & entertainment in mind, it downloads and accelerates video, iTunes, IOS updates, app downloads, and other content for uninterrupted learning and fun anytime. The MediaFast can prefetch content during off-peak hours, saving connectivity costs and reducing network burden during busy times.
1Gbps Multi-WAN (7 Ports) Content Caching Router MediaFast 750 #2
Works With
  • iTunes
  • iOS Updates
  • TED.com
1Gbps Multi-WAN (7 Ports) Content Caching Router MediaFast 750 #3
Hassle Free Solution for Campus Connectivity
  • Infinite playback of cached content. Save money and eliminate network congestion.
  • More effective use of time in class. Focus on learning and teaching, not loading.
  • Central Management Platforms, your one stop management and monitor station.
Stable Connectivity
Peplink routers enable you to add bandwidth, wired or wireless, anytime and load balance multiple Internet links. Automatic failover allows you to maintain an unbreakable connection. You can download media-rich course materials effortlessly with the MediaFast.
1Gbps Multi-WAN (7 Ports) Content Caching Router MediaFast 750 #5
Prefetch Off-Peak Downloads
Schedule one-time or recurring content downloads during off-peak hours, and then playback downloaded content anytime. Need HD video and other content in places with spotty or congested Internet connections? Download whenever and wherever the connection is best. Then pack up and take the MediaFast anywhere you need seamless content delivery
1Gbps Multi-WAN (7 Ports) Content Caching Router MediaFast 750 #6
Reporting.
Deep Insights.
On-Demand.
Check bandwidth usage and savings. Track popular URLs and file types. Monitor client IP addresses, find your heaviest users, and more, all from a single intuitive interface.
1Gbps Multi-WAN (7 Ports) Content Caching Router MediaFast 750 #7
Cache.
Download x1.
Playback x∞.
Cache iTunes/iTunes U and other content automatically by domain and file type. With MediaFast, you can download once and play back over and over again, cutting loading time, bandwidth usage and cost. Keep content as long as you like or purge it automatically by file type and age.
1Gbps Multi-WAN (7 Ports) Content Caching Router MediaFast 750 #8
Complete Solution & Centralized Management
MFA 750  is supported by InControl 2, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
  •  School/Campus
    ModelMediaFast 750
    Product CodeMFA-750-AMFA-750-B
    CategoryWired Only
    Ethernet WAN Ports1/7 &7
    Embedded 4G LTENoNo
    Wi-Fi InterfaceNoNo
    USB 4G LTE/3G WAN [1]11
    Disk Drive240GB SSD1TB SSD
    Cache Throughput [2]1Gbps 1Gbps
    Router Throughput [3]1Gbps1Gbps
    Ethernet LAN Ports3 (GbE)3 (GbE)
    Core Functionality
    Load BalancingNo ^Yes
    Video CachingYesYes
    Content CachingYesYes
    InControl Cloud ManagementYesYes
    Drop-In ModeYesYes
    GPS Fleet ManagementNoNo
    AP Controller
    Manage Pepwave AP SeriesYesYes
    Maximum Number of AP Supported20/250 #20/250 #
    Manage Remote AP & Multiple Config ProfilesNo °No °
    VPN Functionality
    PepVPNYesYes
    SpeedFusion Hot FailoverNo ^Yes
    SpeedFusion Bandwidth BondingNo ^Yes
    Number of PepVPN/SpeedFusion Peers2/300 %300
    PepVPN Throughput (No Encryption)400Mbps400Mbps
    PepVPN Throughput (256-bit AES)400Mbps400Mbps
    Advanced QoS Functionality
    Bandwidth Usage MonitorYesYes
    QoS for VoIP and E-CommerceYesYes
    User Groups Bandwidth ControlYesYes
    Web BlockingYesYes
    Hardware
    Operating Temperature32° – 104°F
    0° – 40°C
    32° – 104°F
    0° – 40°C
    Power Consumption70W70W
    1U Rack-mountYesYes
    LAN BypassYesYes
    Router Throughput and PepVPN/SpeedFusion Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments. Figures apply to the latest hardware revision. The throughput result is tested with DHCP/Static IP WAN.
  • WANWAN Support for PPPoE
    Static IP
    DHCP WAN Link Health Check
    Bandwidth Allowance Monitor
    USB 4G LTE/3G Modem Support
    Support for Dynamic DNS
    Services IPv6 Support
    Extended DHCP Options
    DHCP Reservation
    DNS Proxy for LAN Clients
    DNSBuilt-in Authoritative DNS
    Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
    QoSUser Groups
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Content CachingVideo Caching
    iTunes
    iTunes U
    TED.com
    Content Caching
    HTML
    JavaScript
    Flash Applications
    AP ControllerSupport for Pepwave AP Series
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi usage statistics
    Command Line Interface
    Router Utility Mobile App
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Complete VPN SolutionSpeedFusion VPN/ SpeedFusion
    Site-to-Site VPN
    Bandwidth Aggregation
    Intelligent Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    PPTP VPN Server
    RADIUS, LDAP Authentication
    Security Stateful Firewall
    DoS Prevention
    Web Filtering Blacklist
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
  • Product CodeProduct NameProduct Description
    MFA-750-BMediaFast 750
    Caching Router for Education and Enterprise
