Advanced Dual-WAN Router for Branch Networking
USB LTE Connectivity
Plug in a USB modem to use an LTE connection for load balancing and failover. The Balance One’s USB port supports more than 250 4G LTE/3G modems used by a variety of carriers worldwide.
Ultimate Performance
Featuring 600Mbps throughput the Balance One keeps connections dependable and fast with automatic balancing and failover between links.
8x GbE LAN Ports
Connect all your devices at high speeds, without complicated setup, or external switches.
Integrated Wi-Fi AP
Balance One gives you two independent networks that also work together, so all your devices can connect without clashing. Recommended Concurrent Users Per Radio is 60.
Enterprise Features
Connect remote clients to your private network using L2TP with IPsec, monitor Bandwidth Usage, allocate bandwidth on application, and more
Remote User VPN
QoS: Assign Priority
Content Blocking
Balance Portfolio.
SD-WAN for enterprise of all sizes.
Peplink ‘s line of products includes features that make your enterprise deployment easier and increase your network reliability and security in several ways. Boost network data rates, reliability, and flexibility while slashing connectivity costs with Peplink SD-WAN technology designed for multi-WAN link load balancing. Use Load Balancing and SpeedFusion bandwidth bonding to deliver superfast VoIP, video streaming, and data using an SD-WAN enabled network.
Branch/Small Office
Small Business
Mid-Size Business
Large Enterprise/Campus
Cloud/VM
Built to Last
Built in AP Controller
Built in AP Controller puts you in charge of all connected access points, create and manage custom captive portals. It allows you to manage your wireless network from your router and easily build a custom captive portal for your business.
Balance One is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
Web Admin Demo
#PowerofPeplink
Product Code BPL-ONE-CORE BPL-ONE Ethernet WAN Ports 2/5* 2/5* USB WAN Modem Port Yes Yes Router Throughput^ 600Mbps/400Mbps* 600Mbps/400Mbps* Recommended Users 1-60 1-60 Simultaneous Dual-Band 802.11ac/a/b/g/n Wi-Fi AP No Yes Ethernet LAN Ports 8/5*(GE) 8/5*(GE) Port-Based VLAN Yes Yes Load Balancing Yes Yes Drop-In Mode No No Inbound Load Balancing No No InControl Cloud Management Yes Yes PepVPN Yes Yes SpeedFusion Hot Failover Add-On Add-On SpeedFusion Bandwidth Bonding Add-On Add-On Number of PepVPN Peers 2/5¹/10²/20³ 2/5¹/10²/20³ PepVPN Throughput (256-bit AES)^ 30Mbps 30Mbps PepVPN Throughput (No Encryption)^ 60Mbps 60Mbps Per-User Bandwidth Control Yes Yes QoS for VoIP and E-Commerce Yes Yes Web Filtering Blacklists Lite Lite ¹ Can be increased to 5 Peers using license PVN-LC-05
² Can be increased to 10 Peers using license PVN-LC-10
³ Can be increased to 20 Peers using license PVN-LC-20
* If the WAN Activation License (BPL-ONE-LC-5WAN) is activated, router throughput will be changed to 400Mbps, both number of WAN and LAN will become 5.
WAN Link Health Check
Bandwidth Allowance Monitor
USB 4G/3G Modem Support
Intelligent Failover
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
Complete VPN Solution PepVPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding 3
Site-to-Site VPN
Bandwidth Aggregation
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
L2TP with IPsec VPN Server
PPTP VPN Server
RADIUS, LDAP Authentication
IPsec VPN (Network-to-Network) 6Security Stateful Firewall
DoS Prevention
Web Blocking
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Command Line Interface
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Package Content Balance One
12V Power Supply
Certifications FCC, CE, RoHS -
Product Code Description BPL-ONE-LC-SF SpeedFusion bandwidth bonding license BPL-ONE-LC-5WAN Define LAN 1-3 to WAN 3-5 PVN-LC-05 Enables up to 5 PepVPN connections PVN-LC-10 Enables up to 10 PepVPN connections PVN-LC-20 Enables up to 20 PepVPN connections -
Product Code Description BPL-ONE-CORE Balance One Core BPL-ONE Balance One
