B One Cover Background Image
B One Cover Image
BOne
Impressive Capability with Incredible Value
$299* MSRP
*Pricing applies to US region only, other regions may vary.
Taking the best parts of the beloved Surf SOHO & Balance 20 and putting them into one capable device.
Improved Speeds & Wi-Fi
Enterprise Software Features
Enterprise Software Features Line
Separate devices into VLANs
Multiple SSIDs
WLAN Controller
Robust & Reliable Connectivity
Great Value
Great Value
Easy Integration with Starlink
  • Bond multiple Starlink connections together
  • Load Balance your Starlink with other internet services (5G/LTE, Cable, Fiber, FWA)
  • Optimize your network with additional features requested specifically by Starlink
B One with Starlink
Made for Fixed Wireless Access (FWA)
  • Designed for use with MSP 5G/LTE Gateway devices
    • Bond various FWA together (AT&T / T-Mobile / Verizon)
    • Load Balance different internet sources (Cable, Fiber, 5G/LTE)
  • Tether your phone with Wi-Fi WAN or USB
B One with FWA
Long Term Support
  • Firmware is constantly updated to patch vulnerabilities and improve performance
  • Futureproof your network as Peplink never ends support for older devices
B One Firmware Support
Peplink App
A Game Changer with Peplink App
  • With a valid PrimeCare subscription, take advantage of all of SpeedFusion features without the need for an advanced network setup
  • Easy to set up and use with our Companion App
B One with Peplink App
Key B One Benefits
Dual WAN
Dual WAN
architecture keeps you connected even when one of your Internet lines goes down
SpeedFusion
SpeedFusion
technology seamlessly bonds multiple Internet connections into one more reliable Internet feed
Use Cases
Use Case - Soho
Use Case - Retail
Port and Connections
B One Spec Front B One Spec Back
Product Image
Model:
Buy Online
    SoftwarePepwave MAX Firmware
    WAN Link Health Check
    Bandwidth Allowance Monitor
    IPv6 Support
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    -Weighted Balance
    -Priority
    -Overflow
    -Persistence
    -Least Used
    -Lowest Latency
    -Enforced
    -Fastest Response Time
    - Site-to-Site VPN
    - SpeedFusion Hot Failover^
    - SpeedFusion WAN Smoothing^
    - SpeedFusion Bandwidth Bonding ^
    - 256-bit AES Encryption
    - Pre-shared Key Authentication
    - Dynamic Routing
    - PPTP VPN Server
    - RADIUS, LDAP Authentication
    IPsec VPN (Network-to-Network)@
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    Advanced QoSIndividual Bandwidth Limit
    Application Prioritization
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Wi-Fi Usage Statistics
    Auto AP Firmware Management
    AP Profile Configuration
    Support RADIUS Authentication
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    ^ Requires a PrimeCare subscription, complimentary for the first year.
    @   IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
  • Product CodeRegions
    B-ONE-T-PRMGlobal
    Product Code Description
    PRM-A-1Y PrimeCare A (1-Year)
    PRM-A-2Y PrimeCare A (2-Year)
    PRM-A-4Y PrimeCare A (4-Year)
    PCP-A-1Y PrimeCare+ A (1-Year)
    PCP-A-2Y PrimeCare+ A (2-Year)
    PCP-A-4Y PrimeCare+ A (4-Year)
    ACW-634 10ft DC Power Cable
    • 1x B One
    • 2x Wi-Fi Dual Band Antennas
    • 1x 12V 3A 4 Pin Power Supply
