MAX Industrial 4G Router
Model Types
Industrial 4G Routers
The MAX series of industrial 4G routers are designed to provide secure WAN access in environments where wired solutions are too expensive to deploy. The MAX series feature GPS fleet tracking, serial-to-IP terminal services, VPN security, and a wide temperature range. These features make them ideal for enabling fleet management, video surveillance,
Internet of Things (IoT) and machine-to-machine M2M deployments. InControl central management simplifies your network making it scalable while SpeedFusion VPN protects the integrity of remote access and connectivity to critical devices.
Work with Verizon, Sprint, AT&T and T-Mobile
industrial 4g router SpeedFusion Bonding
SpeedFusion Bandwidth Bonding
SpeedFusion Bandwidth Bonding combines all connected bandwidth into a single superfast stream, using the same or different providers.
industrial 4g router rugged metal construction
Built Tough
MAX industrial 4G routers can withstand punishment and extreme temperatures. IP67 outdoor routers can take on any environment.
industrial 4g router dual sim
Dual SIM Slots
Dual SIM slots allow you to use two SIM cards for each single cellular modem, increasing your coverage.
industrial 4g router GPS fleet tracking
GPS Fleet Tracking
Use InControl to keep tabs on the location of each vehicle and manage your mobile network from any Internet-connected device.
industrial 4g router terminal block
Terminal Block
Serial-capable terminal blocks assist in securing power to the device as well as enabling M2M device communication.
industrial 4g router certifications
Multiple Certifications
Certifications include: FCC, CE, RoHS, E-Mark, Shock and Vibration Resistance, Railway Applications, and Electromagnetic Compatibility.
Any Questions?
