Designed for enterprise networks, and stays connected even if a WAN link breaks. Equipped with a wide range of load balancing algorithms to handle any situation.
Balance Series
Wireless SD-WAN
Best Value in SD-WAN. Expandable to Dual 4G LTE.
Enjoy LoRaWAN and SpeedFusion Concurrently.
5G Hybrid Enterprise Branch Connectivity.
5G/Fiber Hybrid Enterprise Branch Connectivity.
Enterprise SD-WAN Router for Medium-Sized Branches.
Fixed and Advanced Wireless Broadband SD-WAN Router.
SD-WAN
Link Aggregation and Load Balancing Across 5 WAN Connections.
Edge-Ready, Fail-Safe, and Performance-Packed
Edge Computing at its Peak.
Meet the Next Generation Enterprise Router – Speed, Reliability and Raw Performance
SDX Series
Modularized for Maximum Flexibility.
Modular SD-WAN Router with Edge Computing Capability.
EPX Series
Highest Performance Ensured.
