AP One Rugged
Case Durable • Price Unbeatable
    Locate a Reseller
AP One Rugged Image
The AP One Rugged is made for times
where you need Wi-Fi in extreme environments.
Its tough exterior allows for smooth operation in -40°F/-40°C to 149°F/65°C environments.
AP One Rugged Top View AP One Rugged Cold Temp AP One Rugged Hot Temp
Power the device normally through Power over Ethernet for less cable management, or an industrial microfit connector for a secure and durable power option.
AP One Rugged Front View AP One Rugged PoE AP One Rugged Micro-Fit
It’s resistant to shock, vibrations and electromagnetic waves with the certifications to prove it.
AP One Rugged Shock
The DIN rail mount system allows for flexible deployment, no matter if it’s on a wall, on a pole or on the ceiling.
AP One Rugged DIN Rail Mount
AP One Rugged Wi-Fi Mesh and IC2
Take full control of your network
This isn’t just your everyday access point. With Wi-Fi mesh support, you can eliminate blindspots in your network, and easily control all your devices with InControl 2.
AP One Rugged GE Ports
Ethernet available whenever you need it
It’s not just limited to simply providing Wi-Fi either. Boost your devices with wired connections through its 3 GE ports. Having options gives you the power to deploy however you want.
Ports and Connections
AP One Rugged Front Ports
AP One Rugged Rear Ports
Product Image
Model:
Buy Online
Photos
    NetworkBridge Mode
    Router (NAT) Mode
    Mesh
    Wireless Distribution System (WDS)
    Management VLAN
    Spanning Tree Protocol
    RadioMultiple SSID
    Auto Channel Selection
    Transmit Power Adjustment
    Neighbor AP Detection
    AP SecurityOpen
    WPA/WPA2/WPA3-Personal
    WPA/WPA2-Enterprise
    InControl Cloud Management
    Peplink AP Controller
    SNMP v1, v2c and v3
    Client ManagementPer SSID
    VLAN with QoS (802.1p/802.1q)
    Bandwidth Control
    MAC Address Filtering
    Layer 2 Client Isolation
    Limit on Max. Number of Clients
    Per Client
    VLAN with RADIUS
    VLAN with VLAN
    Pool Bandwidth Control
    Multicast Filter
    IGMP Snooping/Multicast Enhancement
    Captive Portal by InControl
  • Product CodeName Description
    APO-AC-RUGAP One RuggedWi-Fi 5 2x2 MIMO Access Point
  • “Fantastic access points with seamless device handoff. Works best with a Peplink router. Highly recommended.”
    – Ecommerce Customer Feedback
    “Easy to set up. Very powerful unit. Does the job very well.”
  • Product CodeDescription
    SVL-413EssentialCare (1-Year) for AP One Rugged
    SVL-513EssentialCare (2-Year) for AP One Rugged
    ACW-DIN-BR1-MINIDIN Rail Mount for BR1 Mini / AP One Rugged
    ECP-A-1YEssentialCare+ A (1-Year)
    ECP-A-2YEssentialCare+ A (2-Year)
    ECP-A-4YEssentialCare+ A (4-Year)
  • AP One Rugged
    • AP One Rugged
    • 12V2A Power Supply (ACW-632)
    • 2 x Wi-Fi Antenna (ACW-342)
