![MAX BR1 Classic](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2022/07/BR1_Classic.png/w=9999)
MAX BR1 Classic
This product is out of stock.
Recommended Alternatives
Deploy & Forget
Set up your BR1 Classic in minutes, and then let it connect your network for years without worry. The current uptime record for a Peplink device is 1,252 days and counting.
![Automatic Failover 4G LTE Mobile Router MAX BR1 #3](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-3-1.png/w=992)
Supports Python
GPIO Terminal Block
Small Form Factor
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-4.jpg/w=2560)
Certified Toughness
In addition to rugged metal enclosure, the BR1 Classic is certified on:
Shock and vibration resistance
(EN 61373:1999, IEC 61373:1999)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
![Automatic Failover 4G LTE Mobile Router MAX BR1 #5](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-5.jpg/w=992)
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo & terms and conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
![Automatic Failover 4G LTE Mobile Router MAX BR1 #6](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-6.jpg/w=992)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/08/Max-Demo-photo.jpg/w=992)
To help you better understand the powerful features offered the Pepwave MAX cellular router, we would like to invite you to check out our online demo.
Class 1 Div 2 ready
Hazardous locations need connectivity too. Good news for you, the BR1 Classic is Class 1 Div 2 compatible out of the box so it’s ready to be deployed at even the harshest of conditions, providing you with unbreakable connectivity.
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/11/BR1-classic-hazloc.png/w=992)
#PowerofPeplink in Action
![Automatic Failover 4G LTE Mobile Router MAX BR1 #7](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-7.jpg/w=992)
![Automatic Failover 4G LTE Mobile Router MAX BR1 #8](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-9.jpg/w=992)
![Automatic Failover 4G LTE Mobile Router MAX BR1 #9](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-8-1.jpg/w=992)
![Automatic Failover 4G LTE Mobile Router MAX BR1 #10](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-10.jpg/w=992)
![Automatic Failover 4G LTE Mobile Router MAX BR1 #11](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-11.jpg/w=992)
![Automatic Failover 4G LTE Mobile Router MAX BR1 #12](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Automatic-Failover-4G-LTE-Mobile-Router-MAX-BR1-12.jpg/w=992)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/max_br1_classic_web_v2-01.png/w=1241)
