![Device Connector IP55](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2022/07/Device_Connector_IP55.png/w=9999)
This product is out of stock.
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Long-Range-Wireless-Bridge-Device-Connector-IP55-3.jpg/w=2560)
Use Cases
Public Safety
Retail
Hospitality
One Access Point, Multiple Devices
Sample Topology
![Long Range Wireless Bridge Device Connector IP55 #4](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Long-Range-Wireless-Bridge-Device-Connector-IP55-4.png/w=992)
Multiple devices could connect to headquarters using both the 2.4GHz and 5 GHz frequencies coming from a single AP. This is achieved by hooking up a Device Connector IP55 to each device, and then connecting them any AP. Using this configuration, the device connector will be able to form SpeedFusion connections with the Balance Router located at the network infrastructure, providing the enhanced reliability of combined bandwidth.
Consistent Wi-Fi Coverage & Reliable Connectivity
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Long-Range-Wireless-Bridge-Device-Connector-IP55-5.jpg/w=2560)
Plug-and-Play
Easily extend Wi-Fi coverage in minutes with Pepwave’s Device Connector IP55. The Device Connector gets your devices talking over a large area without wires or configuration headaches. And because it works transparently at Layer 2, the Device Connector is compatible with any access point.
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Long-Range-Wireless-Bridge-Device-Connector-IP55-6.jpg/w=2560)
Merge 2.4GHz & 5GHz Signals
Normally, Wi-Fi devices will force you to choose between 5GHz or 2.4GHz. With the Device Connector IP55, you can have both. Simply connect your device to the Ethernet port and the device connector will combine 5GHz and 2HGz into a single reliable connection.
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Long-Range-Wireless-Bridge-Device-Connector-IP55-7.jpg/w=2560)
Advanced Roaming
Advanced Roaming lets your Device Connector IP55 seamlessly hop from AP to AP in a matter of seconds. Whether you’re commanding an emergency situation, coordinating a construction project, or keeping your warehouse stocked, Advanced Roaming keeps everyone communicating at all times.
Compact Super-Duty IP55 Enclosure
The Device Connector IP55 has a waterproof IP55 enclosure that stands up to dust, vibration, and inclement weather.
![Long Range Wireless Bridge Device Connector IP55 #8](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Long-Range-Wireless-Bridge-Device-Connector-IP55-8.png/w=992)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2021/01/Device-Connector-IP55-_index-dia_3.png/w=992)
