Slim Antennas
Applications
Recreational Vehicles
Transportation Connectivity
Home / Office
Home / Office
Ultra Wide Bandwidth
Wide frequency range (600-6000MHz) for LTE and 5G connections, including B71.
Built for 5G*
Omni-directional 2×2 or 4×4 MIMO mobile antenna for the best performance.
Wi-Fi^
2×2 MIMO dual band (2.4GHz & 5GHz) high gain omnidirectional antennas for local coverage.
*Slim 22G is equipped with 2×2 MIMO mobile antenna and Slim 40G is equipped with 4×4 MIMO
mobile antenna.
^Wi-Fi antenna only available for Slim 22G.
Built for 5G*
Wi-Fi^
mobile antenna.
Low Profile Design
High performance in a small size and durable housing.
Easy Installation
Can be mounting on a wall window or wall or hidden under a vehicle dashboard.
Low Profile Design
Easy Installation
Slim 22G
2x Cellular | 2x Wi-Fi | 1x GPS
Slim 40G
4x Cellular | 1x GPS
Product Code Description ANT-SLM-22G-S-B-6 2xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, SMA, Black, 6.5 ft / 2m ANT-SLM-40G-S-B-6 4xLTE/5G, 1xGPS 600-6000MHz, SMA, Black, 6.5 ft / 2m -
Slim 22G
- 1x Slim 22G
- Velcro strip (hook and loop fastener)
(4pcs, length 4.7′ / 120mm)
Slim 40G
- 1x Slim 40G
