MediaFast Specifications
bpl-mfa-icon.fwBalance with MediaFast
eLearning Enabler
max-mfa-icon.fwMAX with MediaFast
Mobile/Remote Networking Accelerator
Model Comparison
 Branch Office/HotspotSchool/Campus
ModelBalance with MediaFast 200Balance with MediaFast 500Balance with MediaFast 750Balance 580Balance 710
Product CodeMFA-200-WMFA-500-BMFA-750-BBPL-580BPL-710
Recommended Users500300-1000500-2000300-1000500-2000
Capacity
Disk Drive128GB SSD500GB SSD1TB SSDspec_nonespec_none
Cache Throughput2200Mbps1.5Gbps2.5Gbpsspec_nonespec_none
Router Throughput3200Mbps800Mbps1.5Gbps1.5Gbps2.5Gbps
Ethernet WAN Ports25757
Ethernet LAN Ports8 (GE)
802.3af PoE Output+
3 (GE)3 (GE)3 (GE)3 (GE)
Wi-Fi InterfaceSimultaneous Dual-Band 802.11a/b/g/n APspec_nonespec_nonespec_nonespec_none
USB WAN Modem Port111111
Wi-Fi Data Rates42x2 MIMO,
2.4GHz: 300Mbps
5GHz: 300Mbps
Core Functionality
Load Balancing & Failover
Load Balancing Algorithms77777
Inbound Load Balancingspec_none
Video Caching spec_nonespec_none
Content Caching spec_nonespec_none
InControl Cloud Management
Docker Container Supportspec_none spec_nonespec_none
Drop-In Mode
IPsec/L2TP/PPTP VPN Functionality
IPsec VPN (Network-to-Network)5
Number of IPsec Tunnels25015050150
L2TP VPN Server
PPTP VPN Server
Recommended PPTP VPN Users15100200100200
AP Controller Functionality
Manage Pepwave AP Series
Maximum Number of AP Supported50100250100250
Manage Remote AP & Multiple Config Profilesspec_none
PepVPN/SpeedFusion Functionality
PepVPN
SpeedFusion Hot Failoverspec_none^
SpeedFusion WAN Smoothingspec_none^
SpeedFusion Bandwidth Bondingspec_none^
Number of PepVPN/SpeedFusion Peers25030050300
PepVPN/SpeedFusion Throughput50Mbps200Mbps400Mbps200Mbps400Mbps
Advanced QoS Functionality
Bandwidth Usage Monitor
QoS for VoIP and E-Commerce
User Groups Bandwidth Control
Web Blocking
Web Filtering BlacklistLightFullFullFullFull
Hardware
Operating Temperature32° – 104°F
0° – 40°C
Power Consumption38W50W70W50W70W
1U Rackmount
High Availability
LAN Bypassspec_none
1 For a list of supported modems, please refer to /modem.
2 Cache Throughput refers to the speed of routing content from hard disk to LAN.
3 Router Throughout is only valid for devices running Firmware 7.0.1 or later. Router Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments.
4 The frequency range for 2.4GHz and 5GHz are 2412−2472 MHz and 5180−5825 MHz respectively.
+ Optional PoE Activation Kit is required to activate 802.3af PoE output.
^ Available as an optional add-on.
See Peplink MediaFast Features
GO
MediaFast 200 – Ordering Info
orderinfo_mfa-200
Product CodeDescription
MFA-200-WContent caching router with 120GB SSD. Supports InControl 2, AP Controller and mobile device management.
Feature Add-On
Product CodeFeature Pack
MFA-200-LC-SFLoad Balancing and SpeedFusion Bonding License Key for MediaFast 200
PoE Activation Kit
ACW-609Includes 1x 48V Power Supply and PoE License
Enables 4x 802.3af PoE Output Ports
Requires 2x ACW-609 to enable all PoE ports in the MediaFast device
MediaFast 500 – Ordering Info
orderinfo_mfa-500
MFA-500-BContent caching router with 500GB SSD. Supports InControl 2, AP Controller and mobile device management.
MediaFast 750 – Ordering Info
orderinfo_mfa-750
MFA-750-BContent caching router with 1TB SSD. Supports InControl 2, AP Controller and mobile device management.
Contact A Reseller
Technical Specifications
5 Only valid for customers who have purchased Peplink Balance devices directly from Peplink.
Feature not available in every model. Please refer to model comparison for details.
