MAX Transit Pro
| Redefining Pro
Wait no more, experience the new fast
Why settle for less advanced Wi-Fi, throughput and SpeedFusion speed?
Experience it all, but faster with Wi-Fi 6!
It’s got the power!
Achieve non-stop power for fixed deployments or on-the-go mobile deployments with duo USB-C power bank input ports. Equipped with a Micro-Fit power connector to secure your power source, ensuring that your device remains powered on with no outage. Believe it’s got the power!
Poor connectivity? No problem!
A simple connection to SpeedFusion Cloud keeps your connection unbreakable. With intricately placed endpoints globally, it ensures you remain connected wherever you are.
Elevate the way you manage SIMs
Elevate the way you manage SIMs with eSIM support and sophisticated hardware like the SIM Injector. Manage SIMs more efficiently from anywhere, at any time.
Safeguard your applications
MAX Transit Pro offers flexibility in the ways you can create PepVPN tunnels, enabling 256-bit AES Encryption to ensure your applications are kept protected, so that you can browse with confidence.
Running applications just got easier!
Want to run third party applications directly with your MAX Transit Pro?
Well now you can! With edge computing Docker and Python*, the possibilities are endless!
*Feature will be available soon.
MAX Transit Pro
WAN Link Health Check
Bandwidth Allowance Monitor
IPv6 SupportLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted Balance
-Priority
-Overflow
-Persistence
-Least Used
-Lowest Latency
-Enforced
-Fastest Response Time
Complete VPN Solution PepVPN
SpeedFusion
– Site-to-Site VPN
– SpeedFusion Hot Failover^
– SpeedFusion WAN Smoothing^
– SpeedFusion Bandwidth Bonding ^
– 256-bit AES Encryption
– Pre-shared Key Authentication
– Dynamic Routing
– PPTP VPN Server
– RADIUS, LDAP Authentication
IPsec VPN (Network-to-Network)@Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
Security 128-bit WEP
WPA & WPA 2
Stateful Firewall
DoS Prevention
Web Blocking
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage StatisticsGlobal Positioning System Integrated GPS
Device Location Map
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Social Wi-Fi Hotspot support
External Captive Portal supportCertifications -FCC, CE, RoHS, IC
-E-Mark*
-EN 61373:1999 IEC 61373:1999 Shock and Vibration Resistance*
-EN 50155 Railway Applications – Electronic Equipment used on Rolling Stock*
-EN 61000 Electromagnetic Compatibility*Device Management Web Administrative Interface
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
^ Requires a PrimeCare subscription, complimentary for the first year.
@ IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
* Certification pending. -
Product Code Embedded
Modem(s)Regions LTE Bands 3G Bands MAX-TST-PRO-DUO-LTEA-USR-T-PRM 1x CAT-12
1x CAT-7Primary: North America* Cellular 1 (CAT-7):
B2, B4, B5, B7, B12, B13, B14, B25,
B26, B41, B42, B43, B48, B66, B71
Cellular 2 (CAT-12):
B1, B2, B3, B4, B5, B7, B8, B9, B12,
B13, B14, B18, B19, B20, B26, B29,
B30, B32, B41, B42, B43, B46, B48,
B66Cellular 1 (CAT-7):
HSPA+: B2, B4, B5
HSPA+: B1, B2, B4, B5,
B6, B8, B9, B19MAX-TST-PRO-DUO-LTEA-D-T-PRM 2x CAT-12 Primary: APAC & EMEA B1, B2, B3, B4, B5, B7, B8, B9, B12,
B13, B14, B17, B18, B19, B20, B21,
B25, B26, B28, B29, B30, B32, B38,
B39, B40, B41, B66HSPA+: B1, B2, B3, B4,
B5, B8, B9, B19MAX-TST-PRO-DUO-LTEA-E-T-PRM 2x CAT-7 Primary: EMEA B1, B3, B7, B8, B20, B28, B32, B38,
B40, B41, B42, B43HSPA+: B1, B5, B8 *US Carrier Certifications (Pending): AT&T, T-Mobile, Verizon.
Product Code
Description
PRM-MAX-TST-PRO-DUO-LTEA-1Y
1-Year PrimeCare for Transit Pro
PRM-MAX-TST-PRO-DUO-LTEA-2Y
2-Year PrimeCare for Transit Pro
PRM-MAX-TST-PRO-DUO-LTEA-4Y
4-Year PrimeCare for Transit Pro
ACW-DIN-TST
DIN Rail Mount
ANT-MB-42G-S-B-6
7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
ANT-MB-42G-S-W-6
7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
MAX Transit Pro
- MAX Transit Pro
- 4x LTE Antennas (ACW-234)
- 2x Wi-Fi Dual Band Antenna (ACW-341)
- 1x GPS Active Antenna (ACW-232)
- 1x 12V 2A 4 Pin Power Supply (ACW-632)
- 1x 6 Pin Terminal Block Connector
- 1 Pair of Mounting Brackets (ACW-724)
