BR2 Pro
Designed for Pros, by Pros.
Faster, Wider, Stronger
The BR2 Pro is not just designed to be tough. Its dual 5G connections, Wi-Fi 6 and PoE input ensure an unbreakable connection in any scenario.
Peace of Mind
With so many WAN options, the BR2 Pro can seamlessly failover to guarantee your flow of data, even during the most critical circumstances. The Gigabit routing speed and serial port for OOBM allow versatility for any SD-WAN deployment.
Oh, So Many WANs
Complement any SD-WAN deployment with the Dual Ethernet WANs, Dual 5G/LTE, USB WAN, and Wi-Fi WAN. Not enough WANs? Add the MAX Adapter 5G for an instant third 5G connection. Literally, all the WANs to keep you going.
Made for Vehicle applications
Secure your power source in mobile environments with the Molex Micro-Fit power connector. Wide input power range along with Ignition Sensing capabilities makes this a sure fit for your vehicle installs.
Effortless Cellular Extension
With the PoE input feature, the BR2 Pro can seamlessly extend your existing SD-WAN infrastructure to provide dual LTE/5G connectivity. One cable for both power and data, it’s that simple.
SIM-plicity as always
Built-in eSIM and SIM Injector support, the BR2 Pro maximizes your possibilities with flexible remote SIM management.
Watch the film
Ports and Connections
WAN Link Health Check
Bandwidth Allowance Monitor
WAN Port Convertible into LAN PortLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN SupportSecurity Stateful Firewall
DoS Prevention
Web BlockingComplete VPN Solution PepVPN/SpeedFusion
-Hot Failover
-Site-to-Site VPN
-256-bit AES Encryption
-Dynamic Routing
-X.509 Certificate Support *
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSGlobal Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage StatisticsCaptive Portal Support Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3 -
Product Code Embedded Modems Regions 5G Bands LTE Bands MAX-BR2-PRO-5GD-T-PRM 2x 5G Primary: APAC, EMEA
Compatibility: Global5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n20, n28, n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 MAX-BR2-PRO-5GH-T-PRM 2x 5G Primary: North America*
n1, n2, n3, n5, n28, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 -
Product Code
Description
PRM-MAX-BR2-PRO-1Y
1-Year PrimeCare for BR2 Pro
PRM-MAX-BR2-PRO-2Y
2-Year PrimeCare for BR2 Pro
PRM-MAX-BR2-PRO-4Y
4-Year PrimeCare for BR2 Pro ACW-634
10ft Direct Wire DC Cable ANT-MB-42G-S-W-6
7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-42G-S-B-6
7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) -
- 1x MAX BR2 Pro
- 1x 12V3A Power Supply (ACW-602)
- 8x LTE/5G Antennas (ACW-234)
- 2x Wi-Fi Dual Band Antenna (ACW-341)
- 1x GPS Antenna (ACW-232)
