![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #3](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-3.png/w=992)
Redundant SIM Slots for Multiple Carriers
Redundant SIM slots with automatic switching for reliable network. You can also set the MAX BR1 mobile router to automatically switch SIM cards when you’re in danger of exceeding a data cap. It also allows you travel across borders without changing SIM cards manually.
Use Cases
Public Safety
Passenger Wi-Fi
Landline Replacement
Topology
![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #4](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-4-1.png/w=992)
- SpeedFusion delivers unbreakable connectivity using two redundant 4G LTE connections from different carriers.
- In case of a WAN failure, SpeedFusion instantly switches traffic to another connection.
![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #11](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/06/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-11-2.jpg/w=768)
- Setting up a customizable portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS or LDAP servers.
![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #12](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/06/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-12-2.jpg/w=768)
- InControl 2 provides complete cloud-based device management, monitoring, and reporting and let you check vehicle speed, view cellular coverage, and play back route histories in real-time.
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-5-1.jpg/w=2560)
Certified Toughness
In addition to the rugged metal enclosure, the MAX BR1 MK2 mobile router HAS certifications for
Shock and vibration resistance
(EN 61373:1999, IEC 61373:1999)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #6](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-6.png/w=992)
Terminal Block for Secure Power Supply
The MAX BR1 is equipped with a terminal block for secure power installation in vehicles and other locations.
There is More
We specialize in making complicated technologies simple. Achieve what others cannot with the following.
#powerofpeplink
![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #9](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/06/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-9-1.jpg/w=992)
![Verizon Certified Automatic Failover Single Cellular Router MAX BR1 MK2 #10](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/06/Verizon-Certified-Automatic-Failover-Single-Cellular-Router-MAX-BR1-MK2-10.jpg/w=992)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/max_br1_mk2_web_v3-01.png/w=1241)
