The FusionHub Solo brings SpeedFusion to your mobile or small branch office without the need for additional hardware. Install it in your cloud service of choice, and experience unbreakable connectivity and unparalleled speed with bandwidth bonding!
With FusionHub Solo license, you can take full advantage of SpeedFusion using just one Peplink device.
Compatible with All Major Cloud Services
Set up SpeedFusion Technology in a Single Branch
FushionHub Solo can bring SpeedFusion to a single branch, without the need for additional hardware. You’ll be able to access all your applications and resources, with all of the advantages of Peplink’s SpeedFusion technology, including hot failover for an unbreakable connection and our bonding technology for unparalleled speed!
Bonding to Any Cloud
FusionHub gives you freedom and control over your virtual appliance. In addition to being self-deployed and self-managed, you’re able to choose any supported cloud provider and data center location you’d like!
SpeedFusion Unbreakable VPN
Combine any Number of Connections and Boost your Creativity
With the help of smoothing network traffic will be assigned to WAN connection with the lowest latency. Use multiple WAN connections to create a single, jitter-free data streem.
Q1. Is the FusionHub Solo license free?
Yes, the FusionHub Solo license is free of charge. However, if you would like to manage Peplink devices through InControl 2 management, an InControl 2 subscription is required.
Q2. Could FusionHub Solo be installed in any cloud environment, even public clouds?
FusionHub Solo runs on nearly all mainstream virtual machine software including VMware ESXi, Citrix XenServer, Oracle VirtualBox, and Microsoft Hyper-V. Cloud platforms supported include Amazon Web Services, Google Cloud Engine, Microsoft Azure and Vultr. Installation guides can be found here.
Q3. Can FusionHub Solo be installed to multiple cloud environment?
You can install fusionhub on any supported cloud platform. However, you will be limited to one complimentary license. For multiple simultaneous instances or connecting multiple routers, you would need to purchase additional licenses.
Q4. Which model of router will support FusionHub Solo?
Basically all Peplink machines. But some of the models do not support SpeedFusion Hot Failover / SpeedFusion bonding.
Q5. How to acquire the FusionHub Solo license?
1. Log into InControl and access the “Warranty and License” page. < See Screenshot >
2. Under the FusionHub Licenses tab, click “Acquire FushionHub License”. < See Screenshot >
3. Select the “Solo License” option. < See Screenshot >Q6. Does FusionHub Solo support only one peer?
Yes. The idea is to allow customers who own just a single Peplink router also to have the capability to enjoy SpeedFusion SD-WAN technologies.
Q7. Does FusionHub Solo have any bandwidth limitation?
There is no bandwidth limitation.
Q8. Can I upgrade to a higher FusionHub package after using FusionHub Solo?
Sure. Visit this < Link > for more detail.
