Software-Defined (SD) Switch
8 Port anchor 24 Port anchor 48 Port anchor
Expect More from Your Switch
Managing your switches and all connected devices can be a worry-free experience. Yet current switches still
cause as many headaches as they solve. Is your switch smart and easy to use enough to address the following problems?
Solution: Peplink SD Switch with Software Intelligence
Available in:
8-Port SD Switch
8 PoE+ Ports
DC Input, AC Adaptor Included
Industrial Temperature Range
240W Power Budget
24-Port SD Switch
24 PoE+ Ports
Dual Power Input
Multiple PSUs
550 or 850W Power Budget
48-Port SD Switch
48 PoE+ Ports
Dual Power Input
Multiple PSUs, Higher Port Density
800W Power Budget
Industrial Grade Hardware for Tough Environments
Our 8-Port SD Switch has a fanless design and an industrial temperature range, making it perfect for the toughest environments.
8-Port switch dustproof high temperature
You have better things to do than babysit your switches, get the SD Switch now and put your mind to rest.
Where to Buy?
Specifications
ModelSD Switch 8-Port RuggedSD Switch 24-Port 850W
SD Switch 24-Port 550W
SD Switch 48-Port
LAN Interface8x 802.3at (PoE+) GE Ports,
2x 1G SFP Ports
24x 802.3at (PoE+) GE Ports,
2x 10G SFP+ Ports
48x 802.3at (PoE+) GE Ports,
4x 10G SFP+ Ports
VLAN Groups:YesYesYes
AC AdapterAC Input 100V-240V
DC Output 54V*
spec_nonespec_none
Power InputDC Power (DIN Connector): 54V
Terminal Block: 12V-56V
2x 100V – 240V Redundant AC Inputs2x 100V – 240V Redundant AC Inputs
Integrated Power Sourcespec_none850W: 3x Redundant PSU
550W: 2x Redundant PSU
3x Redundant PSU
Power Consumption20W System,
90W PoE+ Power Budget
(Upgradable to 240W*)
50W System,
850W or 550W PoE+ Power Budget
100W System,
800W PoE+ Power Budget
Dimensions8.2 x 6.3 x 1.7 inches
210 x 160 x 45 mm
(L x W x H)
19.1 x 15.7 x 1.7 inches
485 x 400 x 45 mm
(L x W x H)
485 x 400 x 45 mm
(L x W x H)
Weight2.2 pounds
1 kg
13.7 pounds
6.2 kg
15.4 pounds
7 kg
Operating Temperature-40° – 149°F
-40° – 65°C
32° – 104°F
0° – 40°C
32° – 104°F
0° – 40°C
Humidity15% – 95% (non-condensing)15% – 95% (non-condensing)15% – 95% (non-condensing)
Warranty1-Year Limited Warranty1-Year Limited Warranty1-Year Limited Warranty
* The bundled PSU provides 90W of PoE+ power budget. Additional ACW-623 (180W PSU) is required to enable up to 240W power budget.
Peplink SD Switch Dimensions
Ordering Information
Product Code
Description
PSW-8-240W-RUGPeplink SD Switch 8-Port Rugged, 90W power budget (Upgradable to 240W), 8x GE Ports (PoE+), 2x 1G SFP Ports.
PSW-24-850WPeplink SD Switch 24-Port, 850W power budget, 3x power supply units, 24x GE Ports (PoE+), 2x 10G SFP+ Ports.
PSW-24-550WPeplink SD Switch 24-Port, 550W power budget, 2x power supply units, 24x GE Ports (PoE+), 2x 10G SFP+ Ports.
PSW-48-800W Peplink SD Switch 48-Port, 800W power budget, 3x power supply units, 48x GE Ports (PoE+), 4x 10G SFP+ Ports.
ACW-623-USPower Supply Unit for enabling SD Switch 8-Port Rugged (PSW-8-240W-RUG) power budget to 240W, 54V, 3.34A, 180W (For US)
ACW-623-UKPower Supply Unit for enabling SD Switch 8-Port Rugged (PSW-8-240W-RUG) power budget to 240W, 54V, 3.34A, 180W (For UK)
ACW-623-EUPower Supply Unit for enabling SD Switch 8-Port Rugged (PSW-8-240W-RUG) power budget to 240W, 54V, 3.34A, 180W (For Europe)
ACW-623-AUPower Supply Unit for enabling SD Switch 8-Port Rugged (PSW-8-240W-RUG) power budget to 240W, 54V, 3.34A, 180W (For Australia)
