Use Cases
Work From Home
Digital Signage
Remote Metering
Compatible With:
Constant Connectivity
With the BR1 Mini, there is always a way to connect.
Use a combination of cellular, Ethernet, and Wi-Fi WAN to provide users with constant connectivity.
Reliable Hotspot
When working from home, reliable connectivity critical. The BR1 Mini provides this seamlessly: no matter what WAN connection the BR1 Mini uses, the user experience remains consistent.
Deploy Anywhere
The BR1 Mini Core is designed to function where other routers can’t. It is certified for vibration resistance and rolling stock (E Mark, EN 61373, EN 50155, EN 61000). It accepts multiple power inputs and a wide voltage range. Finally, it has an optional mount for Class 1 Div 2 support, and can function in extreme heat and cold.
Small but Sturdy
Benefit from the BR1 Mini’s smaller form factor — without sacrificing durability and reliability. The BR1 Mini has a wide temperature range (-40° to +149°F / -40° to +65°C) and can be deployed in even the harshest environments.
OOBM Support*
Create a modern out-of-band network to manage all your equipment. Give yourself console and Ethernet connectivity to all of your devices. Display your devices console interface over the cloud via InControl so you can securely manage from anywhere without the usual headaches.
*Available with optional accessory (ACW-411)
Optional Class 1 Div 2 support
Extend your connection to hazardous locations and begin enjoying increased productivity. By deploying the BR1 Mini with the optional mount* making it Class 1 Div 2 certified, no longer will you need to worry about the restrictions within these harsh conditions.
*Optional mount ACW-749
#PowerofPeplink in Action
WAN Interface 1x 10/100M Ethernet Port 1x Embedded LTE Modem with Redundant SIM Slot LAN Interface 1x 10/100M Ethernet Port Wi-Fi Interface 802.11b/g/n Wi-Fi WAN or AP PepVPN Yes SpeedFusion Hot Failover Available as additional feature SpeedFusion WAN Smoothing Available as additional feature Drop-in Mode Yes Number of PepVPN SpeedFusion Peers 2/5 * PepVPN/SpeedFusion Throughput (No Encryption / 256-bit AES) 40 Mbps / 20 Mbps Number of IPsec Tunnels 5 Router Throughput 100 Mbps Recommended Users 60 LTE Modem Downlink/Uplink Datarate: 150Mbps/50Mbps LTE-A Modem Downlink/Uplink Datarate: 300Mbps/50Mbps Cellular and GPS Antenna Connector 2x SMA Antenna Connectors
1x SMA GPS Antenna Connector
1x Wi-Fi Connector
Power Input DC Jack/Terminal Block: 12V – 28V DC Passive PoE Input (WAN Port, 12V – 28V DC) Power Consumption 12W (max.) Dimensions 4.1 x 4.3 x 1.2 inches |
105 x 110 x 30 mm
Weight 0.54 pound |
244 grams
Operating Temperature -40° – 149°F |
-40° – 65°C
Certifications -FCC, CE, IC, RoHS, E-Mark,
-EN 61373: Shock and Vibration Resistance,
-EN 50155: Railway Applications – Electronic Equipment used on Rolling Stock,
-EN 61000: Electromagnetic Compatibility
Warranty 1-Year Limited Warranty *2 PepVPN Peers are enabled by default. Can be increased to 5 Peers using license PVN-LC-05.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution PepVPN/SpeedFusion Hot Failover ^
-Site-to-Site VPN
-Hot Failover ^
-256-bit AES Encryption
^ Feature is available as an add-on license.Advanced QoS Individual Bandwidth Limit
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSNetworking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
- MAX BR1 MINI
- 12V2A Power Supply
- 1x GPS Antenna
- 1x WiFi Antenna
- 2x 2dBi 4G LTE Antennas
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-MINI-LTE-US-T United States 1 4G LTE:
B2, B4, B5, B12, B13
HSPA+: B2, B5 MAX-BR1-MINI-LTE-E-T Europe/International 1 4G LTE:
B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 MAX-BR1-MINI-LTE-MX-T Latin America/Australia 1 4G LTE:
B1, B2, B3, B4, B5, B7, B8, B28, B40WCDMA/HSPA+/DC-HSPA+: B1, B2, B5, B8 MAX-BR1-MINI-LTEA-W-T Americas/Europe 1 4G LTE-A:
B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
B1, B2, B3, B4, B5, B8
MAX-BR1-MINI-LTEA-P-T Asia Pacific 1 4G LTE-A:
B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41WCDMA/HSPA+/DC-HSPA+:
B1, B5, B6, B8, B9, B19
TD-SCDMA: B39
Product Code
Description
PVN-LC-05
Enables up to 5 PepVPN peers
MAX-BR1-ADV
Package includes a software license key for Advanced Car-Fi Roaming; and SpeedFusion and IPsec X.509 Certificate Support
MAX-BR1-MINI-LC-FS
Failover software license and related feature set for BR1-MINI, enables Ethernet and Wi-Fi WAN.
ACW-411
Port adapter for BR1 Mini, enables RS-232 console port connectivity while simultaneously providing Ethernet LAN.
ACW-102
PoE injector for delivering passive PoE power to the BR1 Mini.
ACW-749 Class 1 Division 2 Mounting Kit for BR1 Mini
