Redundant SIM Slots for Multiple Carriers
Redundant SIM slots with automatic switching for reliable network. This is particularly useful for remote deployments where connectivity to any given carrier is unreliable. You can also set the MAX M2M mobile router to automatically switch SIM cards when you’re in danger of exceeding a data cap.
Use Cases
Utilities
Industrial
Robotics
Compatible With:
Topology
- Connect your device to the BR1 M2M’s RS232 Serial port.
- The cable connection can failover to cellular.
- Establish a virtual COM port at headquarters to monitor and control the device connected to the BR1 M2M’s port.
Small but Sturdy
Wide Temperature Range
Device has as a wide temperature range (-40° to +149°F / -40° to +65°C) and can be deployed in even the harshest environments.
Din-Rail Mountable
Install your BR1 M2M in minutes with just a screwdriver. It attaches directly to any DIN rail for quick and secure deployment in utility boxes and other locations.
Hot Failover
In case of a WAN failure, SpeedFusion Technology powers the MAX BR1 M2M for instant failover between cellular and Ethernet WAN.
9-pin serial connector
BR1 M2M also features a 9-pin serial connector for easy and durable M2M connectivity.
IoT Ready
With the BR1 M2M you also get all the building blocks of SDN for the future Internet of Things: third party integration, API, and automation. As the IOT evolves, you can be confident your router will be ready.
Fast Setup & Cloud Management
The BR1 M2M has a straightforward and accessible interface. Anyone can get it up and running — no background in IT needed. Plus, the BR1 M2M cloud management capabilities make large-scale management a breeze. You can monitor and manage hundreds of devices on a single screen. Choose from on-premise or public cloud options.
Ethernet WAN Ports 1 (FE) Ethernet LAN Ports 1x FE Embedded 4G LTE 1 Redundant SIM Slots Yes (( Mini-SIM (2FF)) Recommended Users M2M Router Throughput # 100 Mbps PepVPN Yes SpeedFusion Hot Failover Yes Drop-in Mode Yes Number of PepVPN SpeedFusion Peers 2/5 * PepVPN/SpeedFusion Throughput (No Encryption / 256-bit AES) 40 Mbps / 20 Mbps 802.1q VLANs Supported 16 IP Passthrough Yes Web Blocking Yes Web Filtering Blacklist Lite Power Input DC 10V-30V, 2A AC Adapter AC Input 100V-240V
DC Output 12V, 2A
Power Consumption Max.: 10W, Typical: 8.5W, Min.: 6W Dimensions 4.8 x 3.8 x 1.1 inches |
120 x 97 x 26mm
Weight 0.8 pound |
350 grams
Operating Temperature -40° – 149°F |
-40° – 65°C
Certifications -FCC, CE, RoHS
-E-Mark
-EN 61373 Shock and Vibration ResistanceWarranty 1-Year Limited Warranty *2 PepVPN Peers are enabled by default. Can be increased to 5 Peers using license PVN-LC-05.
# Router Throughput and PepVPN/SpeedFusion Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments. Figures apply to the latest hardware revision. The throughput result is tested with DHCP/Static IP WAN.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution PepVPN/SpeedFusion
-Hot Failover
-Site-to-Site VPN
-Hot Failover
-256-bit AES Encryption
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSNetworking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Product Code
Product Name Description
PVN-LC-05
PepVPN License Key for Velocity and BR1 family Enables up to 5 PepVPN peers
MAX-BR1-ADV
Advanced Feature Pack Package includes a software license key for Advanced Car-Fi Roaming; and SpeedFusion and IPsec X.509 Certificate Support
- MAX BR1 M2M
- 12V2A Power Supply
- 2x 2dBi 4G LTE Antennas
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-M2M-LTE-E-T Europe/International
1 4G LTE:
B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
