Use Cases
Data Overage Protection
Temporary Connectivity & Pop up Sites
Cellular Coverage Extension
Compatible With:
Topology
- The BR1 IP67 connects the outside cellular signal with the inside network using just a single PoE cable.
- The switch then delivers the improved connectivity to clients.
Compact Super-Duty IP67 Enclosure
The BR1 IP67 outdoor router is as small as it is tough. It has a waterproof IP67 enclosure that stands up to dust, vibration, and inclement weather.
Dust Protection
Waterproof
Lightning Immune
PoE Input
Cut down on cabling and simplify deployments. The BR1 IP67 supports 802.3af PoE input, so one wire is all you need for both connectivity and power. For non-PoE enabled Ethernet cables, the 802.af PoE Injector is available as a separate accessory.
SpeedFusion Hot Failover
In case of Wi-Fi or cellular WAN failure, the BR1 IP67 supports Hot Failover between the Wi-Fi and cellular WAN connections, giving you session persistence for uninterrupted productivity.
Redundant SIM Slots
Redundant SIM slots with automatic switching for reliable connectivity. You can also set the MAX BR1 IP67 to automatically switch SIM cards when you’re in danger of exceeding a data cap. It also allows you travel across borders without changing SIM cards manually.
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device.applications.
WAN Interface 1x Embedded LTE Modem with Redundant SIM Slot
LAN Interface 1x 10/100M Ethernet Port Wi-Fi Interface 802.11b/g/n Wi-Fi WAN or AP Drop-in Mode No GPS Antenna Integrated Included Antenna Built-In Omni Antenna
Wi-Fi Antenna gain: 5dBi for 2.4GHz,
Cellular Antenna gain: 3dBi for 2.4GHzRecommended Users 1-60 Router Throughput 100 Mbps Number of PepVPN SpeedFusion Peers 2 PepVPN/SpeedFusion Throughput (No Encryption / 256-bit AES) 40 Mbps / 20 Mbps Power Input 802.3af PoE, 48V Passive PoE Power Consumption 12W (max.) Dimensions 5.55 x 6.38 x 3.98 inches |
141 x 162 x 101 mm
Weight 680 g | 1.50 lb Operating Temperature -40° – 149°F | -40° – 65°C
Certifications FCC, CE, RoHS, IC
EN 61000: Electromagnetic Compatibility
Warranty 1-Year Limited Warranty Package Content MAX BR1 IP67, 1 x Waterproof Ethernet Connector Kit -
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution PepVPN/SpeedFusion Hot Failover/
-Site-to-Site VPN
-Hot Failover
-256-bit AES
Encryption
-Dynamic Routing
-X.509 Certificate Support
PPTP VPN Server
-RADIUS, LDAP Authentication
Global Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Advanced QoS Individual Bandwidth Limit
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA support
Captive Portal Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
* IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
Product Code Description ACW-657 Ethernet Power Plug (learn more) -
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-LTE-E-IP67 Europe/International
1 4G LTE:
B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
MAX-BR1-LTEA-W-IP67 Americas/ Europe
1 4G LTE-A:
B1, B2, B3, B4, B5, B7, B8, B12, B13, B20, B25, B26, B29, B30, B41WCDMA/HSPA+/DC-HSPA+:
B1, B2, B3, B4, B5, B8
MAX-BR1-LTEA-P-IP67 Asia Pacific
1 B1, B3, B5 B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
B1, B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
