MAX HD4
Quad 4G LTE Mobile Router
The MAX HD4 delivers outstanding performance from all your connections with the help of SpeedFusion bandwidth bonding and intelligent load balancing.
Quad 4G LTE Mobile Router MAX HD4 #16
Use Cases
Broadcasting
Telemedicine
Disaster Recovery
Public Safety & First Responders
Compatible With:
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #10
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #3
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #5
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #8
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #4
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #9
Sample Topology, Disaster Recovery
In a disaster, reliable connectivity is a must for first responders, aid workers & everyone affected
  1. SpeedFusion creates an unbreakable and bonded connection using multiple 4G LTE/3G modems from different carriers.
  2. In case of a WAN failure, SpeedFusion instantly and seamlessly switches traffic to another connection; for always-on mobile networking.
  3. Multipurpose wireless applications, including video surveillance, VoIP communication, emergency Wi-Fi are possible in disaster recovery projects.
Quad 4G LTE Mobile Router MAX HD4 #4
Quad Embedded Cellular Modems
Quad Cellular Modems and Redundant SIM slots allow you to use up to four different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Quad 4G LTE Mobile Router MAX HD4 #5
Terminal Block for Secure Power Supply
The MAX HD4 is equipped with a terminal block for secure installation in vehicles and other locations.
Quad 4G LTE Mobile Router MAX HD4 #6
8-Port GE Switch and Optional PoE Output
Cut down on cabling and simplify deployments. With a PoE activation kit purchase, the HD4 supports 802.3at PoE Output, so one cable is all you need for both connectivity and power.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD4 is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready & ESN Certified
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD4 supports band 14, providing additional coverage as the situation demands.
MAX HD4 wireless routers are also certified by UK’s Emergency Services Network (ESN). The routers are now approved for use in the country’s fleet of first responders and emergency services vehicles.
Cloud Based SD-WAN Network Management Solution InControl 2
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Quad 4G LTE Mobile Router MAX HD4 #9
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
#PowerofPeplink
  • SoftwarePepwave MAX Firmware
    WAN Link Health Check
    Bandwidth Allowance Monitor
    USB 3G/4G LTE Modem Support
    IPv6 Support
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    Weighted
    Enforced
    Persistence
    Priority
    Overflow
    Least Used
    Lowest Latency
    Fastest Response Time
    Global Positioning Systemntegrated GPS
    Device Location Map
    Location Tracking Data
    GPS eXchange Format (GPX)
    Up to Seven Days
    Complete VPN SolutionSpeedFusion VPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
    Site-to-Site VPN
    Bandwidth Aggregation
    Hot Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    X.509 Certificate Support
    PPTP/L2TP/OpenVPN Server
    Local User, LDAP, RADIUS, Active Directory Authentication
    IPsec VPN (Network-to-Network) 7
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA support
    SecurityStateful Firewall
    DoS Prevention
    Web Blocking
    Advanced QoSUser Groups
    Bandwidth Reservation
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Package ContentMAX HD4
    12V4A Power Supply (ACW-635)
    4x Dual Band Wi-Fi Antennas (ACW-341)
    1x GPS Active Antenna (ACW-232)
    8x 2dBi 4G LTE Antennas (ACW-813)
    1 Pair of Mounting Brackets (ACW-731)
  • Product CodeDescription
    ACW-618Includes 2x 56V/2.1A Power Supply
    Enables 8x 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
    ACW-622Includes 1x 56V Power Supply
    Enables 4x 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
    MAX-HD-020-SPFActivates 20 SpeedFusion VPN/SpeedFusion Peers
    MAX-HD4-LC-5WANWAN Port Activation License for MAX HD4. Convert LAN ports 1-3 to WAN ports 3-5.
    FIPS-LC-HD4FIPS License for HD4
    ECP-MAX-HD4-LTEA-1YEssentialCare+ (1-Year) for MAX HD4 LTEA
    ECP-MAX-HD4-LTEA-2YEssentialCare+ (2-Year) for MAX HD4 LTEA
    ECP-MAX-HD4-LTEA-4YEssentialCare+ (4-Year) for MAX HD4 LTEA
    SVL-4641-Year EssentialCare for MAX HD4 LTEA
    SVL-5272-Year EssentialCare for MAX HD4 LTEA
    ANT-MB-42G-S-W-67-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-42G-S-B-67-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
    ANT-MB-40G-S-W-65-in-1 Cellular Antenna System with GPS Receiver (White)
    ANT-MB-40G-S-B-65-in-1 Cellular Antenna System with GPS Receiver (Black)
    ANT-MB-02-R-W-62×2 MIMO Wi-Fi Dual Band Antenna (White)
    ANT-MB-02-R-B-62×2 MIMO Wi-Fi Dual Band Antenna (Black)
  • Product CodeCarrierEmbedded Modem4G Bands3G Bands
    MAX-HD4-LTE-E-TEurope /
    International /
    CAT-4
    44G LTE:
    B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
    WCDMA/HSPA+/DC-HSPA+: B1, B5, B8
    MAX-HD4-LTEA-W-TWorldwide /
    CAT-6
    44G LTE-A:
    B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
    2500WCDMA/HSPA+/DC-HSPA+:
    B1, B2, B3, B4, B5, B8
    MAX-HD4-LTEA-P-TAsia Pacific /
    CAT-6
    44G LTE-A:
    B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
    B1,B5, B8, B9, B19
    UMTS: B6
    TD-SCDMA: B39
    MAX-HD4-LTEA-WF-TAmerica / FirstNet /
    CAT-12 / CAT-6
    4Cellular 1:
    4G LTE-A Pro:
    B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14, B18, B19, B20, B26, B29, B30, B32, B41, B42, B43, B46, B48, B66
    Cellular 2-4:
    4G LTE-A:
    Cellular 1:
    HSPA+: B1, B2, B4, B5, B6, B8, B9, B19
    Cellular 2-4:
    WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8
    MAX-HD4-LTEA-WK-TGlobal* /
    CAT-12 / CAT-6
    4Cellular 1:
    4G LTE-A Pro:
    B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19, B20, B26, B28, B29, B30, B32, B41, B42, B43, B46, B48, B66
    Cellular 2-4:
    4G LTE-A:
    Cellular 1:
    Cellular 2-4:
    • MAX HD4
    • 1x 12V4.2A Power supply with power cord (ACW-635)
    • 4x Wi-Fi Dual Band Antennas (ACW-341)
    • 1x GPS Antenna (ACW-232)
    • 4x LTE Antennas (ACW-813)
    • 1 Pair of Mounting Brackets (ACW-513)
