BR2 Pro
Designed for Pros, by Pros.
Faster, Wider, Stronger
The BR2 Pro is not just designed to be tough. Its dual 5G connections, Wi-Fi 6 and PoE input ensure an unbreakable connection in any scenario.
Peace of Mind
With so many WAN options, the BR2 Pro can seamlessly failover to guarantee your flow of data, even during the most critical circumstances. The Gigabit routing speed and serial port for OOBM allow versatility for any SD-WAN deployment.
Oh, So Many WANs
Complement any SD-WAN deployment with the Dual Ethernet WANs, Dual 5G/LTE, USB WAN, and Wi-Fi WAN. Not enough WANs? Add the MAX Adapter 5G for an instant third 5G connection. Literally, all the WANs to keep you going.
Made for Vehicle applications
Secure your power source in mobile environments with the Molex Micro-Fit power connector. Wide input power range along with Ignition Sensing capabilities makes this a sure fit for your vehicle installs.
Effortless Cellular Extension
With the PoE input feature, the BR2 Pro can seamlessly extend your existing SD-WAN infrastructure to provide dual LTE/5G connectivity. One cable for both power and data, it’s that simple.
SIM-plicity as always
Built-in eSIM and SIM Injector support, the BR2 Pro maximizes your possibilities with flexible remote SIM management.
Running applications just got easier!
Want to run third party applications directly with your MAX BR2 Pro? Well now you can! With edge computing Docker and Python*, the possibilities are endless!
* Available in firmware 8.3.0.
Watch the film
Ports and Connections
Software Peplink MAX Firmware WAN Support for PPPoE, Static IP, DHCP
WAN Link Health Check
Bandwidth Allowance Monitor
WAN Port Convertible into LAN PortLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN SupportLoad Balancing Multiple Outbound Policy Algorithms
• Weighted Balance
• Priority
• Overflow
• Persistence
• Least Used
• Lowest Latency
• Enforced
• Fastest Response TimeSecurity Stateful Firewall
DoS Prevention
Web BlockingComplete VPN Solution SpeedFusion VPN
• Site-to-Site VPN
• 256-bit AES Encryption
• Pre-shared Key Authentication
• Dynamic Routing
X.509 Certificate Support *
Remote User Access (PPTP/L2TP/OpenVPN)Edge Computing Support on Applications and Docker Advanced QoS Individual Bandwidth Limit
Application Prioritization
• SIP, HTTPS, VPN QoS
• Custom Application QoSGlobal Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMPAP Controller Support for Peplink AP Series
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage StatisticsCaptive Portal Support Support for Wired LAN clients
Support RADIUS Authentication
Command Line Interface
InControl 2 Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3* Feature is available as an upgrade (MAX-BR1-ADV).
^ IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices. -
Product Code Embedded Modem Region 5G Bands LTE Bands MAX-BR2-PRO-5GD-T-PRM 2x 5G Global 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n20, n28, n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 MAX-BR2-PRO-5GN-T-PRM 2x 5G Global*
*US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 MAX-BR2-PRO-5GK-T-PRM 2x 5G North America*
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 -
“The products are rugged and perform well. The ability to connect to multiple data paths, and then prioritize how the paths are used based on cost and performance, is key to getting what we want out of a mobile router. Great reliability in handy form factor”
– Ecommerce Customer Feedback
Product Code Descriptions PRM-E-1Y PrimeCare E (1-Year) PRM-E-2Y PrimeCare E (2-Year) PRM-E-4Y PrimeCare E (4-Year) PCP-E-1Y PrimeCare+ E (1-Year) PCP-E-2Y PrimeCare+ E (2-Year) PCP-E-4Y PrimeCare+ E (4-Year) ACW-111 PoE Adapter ACW-622 PoE+ Activation Kit ACW-634 10ft DC Power Cable ACW-643 Vehicle Cigarette to Molex Power Cable ACW-791 Peplink 4-Pin to USB-C Power Cable ANT-SLM-40G-S-B-6 Slim 40G – 4×4 MIMO 5G Ready Cellular Antenna System with GPS (Black) ANT-MB-42G-S-W-6 Mobility 42G – 4×4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (White) ANT-MB-42G-S-B-6 Mobility 42G – 4×4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (Black) ANT-MB-82G-S-W-6 Mobility 82G – 8×8 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (White) -
- 1x MAX BR2 Pro
- 1x 12V3A 4-Pin Power Supply (ACW-663)
- 8x LTE/5G Antennas (ACW-235)
- 2x Dual Band Wi-Fi Antennas (ACW-341)
- 1x GPS Antenna (ACW-232)
