Certified at:
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #9
Built to Last
Sturdy industrial-strength designed for continuous high-traffic operation.
Portable
The light and sleek enclosure offers portability in the palm of your hands.
Stay Connected
With two SIM slots and an eSIM, the MAX Adapter always has a way to connect.
Compatible with 5G
MAX Adapter now offers a 5G compatible device option. Bringing 5G connectivity to your devices.
SpeedFusion Connect
With a built-in eSIM, achieving on-demand data to minimize data wastage and optimize your connectivity is simple. Do not settle for less, choose SpeedFusion Connect.
Connect with
Peplink Products
Protect and reinforce products^ with a USB port
and make it a 5G/LTE WAN.
^For compatible models, please refer to the MAX Adapter FAQ.
Windows & Linux* Devices
Providing 5G or LTE connectivity
for Windows and Linux devices on-the-go.
* For users on the Linux, please refer to our MAX Adapter
user manual to set up.
Non-Peplink Devices
Place anywhere to optimize cellular reception, reduce truck rolls, expand infrastructure, and maximize uptime for businesses that require always-on connectivity.
  • Cellular WAN InterfacesSingle LTE Modem
    Redundant SIM SlotYes
    Downlink/Uplink
    Datarate
    CAT-12: 600 Mbps/150 Mbps
    CAT-6: 300Mbps/50Mbps
    Antenna Connectors2x SMA Cellular, 1x SMA GPS
    Power Input5V USB-C
    Power Consumption5W (nominal), 8W (max.)
    SIM Slots2
    SIM Card SizeNano-SIM (4FF)
    Dimensions3.9 x 2.8 x 0.6 inches /
    100 x 71 x 15 mm
    Weight120g
    Operating Temperature32° – 104°F / 0° – 40°C
    Warranty1-Year Limited Warranty
    CertificationsFCC, CE, IC
    Package ContentMAX Adapter,
    2x 2dBi 4G LTE Antennas,
    USB-C Female to USB-A Male Adapter,
    USB-C power cable
    US Carrier CertificationsVerizon, AT&T
  • Cellular WAN InterfacesSingle 5G Modem
    Downlink/Uplink
    Datarate
    5G: 4 Gbps / 700 Mbps
    LTE CAT-20: 2 Gbps / 150 Mbps
    Antenna Connectors4x SMA Cellular
    Power Input5V USB-C
    SIM Slots2
    100 x 71 x 15 mm
    Weight120g
    Package ContentMAX Adapter 5G,
    4x 2dBi 4G LTE Antennas,
    USB-C power cable
  • The MAX Adapter is compatible with models which have a USB WAN port. To set up and use your MAX Adapter with a compatible device, you must install operating Firmware 8.1.1 or higher.
    Full list of devices compatible with the MAX Adapter (LTE):
    • Balance series: 20, 20X, 30 LTE, 30 Pro, One, Two, 210, 310 5G, 310 Fiber 5G, 310X, 305, 380, 380X, 580, 580X, 710, 1350, 2500, 2500 EC, MFA500, SDX, SDX Pro
    • Surf SOHO series: Surf SOHO MK3
    • MAX series: BR1 ENT, HD2, HD2 Mini, HD4, MBX, MBX Mini
    • MFA series: HD2/HD4 with Media, MFA 200, MFA500, MFA 750
    Full list of devices compatible with the MAX Adapter (5G):
    • Balance series: 20X, 30 LTE (HW3), 30 Pro, One, Two, 210 (HW4-5), 310 5G (HW2), 310 Fiber 5G (HW2), 310X, 305 (HW2), 380 (HW6), 380X, 580, 580X, 710 (HW3), 1350 (HW2), 2500, 2500 EC, MFA500, SDX, SDX Pro
    • MAX series: BR1 ENT, HD2 (HW5-6), HD2 Mini, HD4, MBX, MBX Mini
  • Q. What is the MAX Adapter and how do I use it?
    The MAX Adapter is a state-of-the-art cellular modem by Peplink, it is not a standalone router. It can be used in two ways to:
    • Add an additional cellular WAN to your existing Peplink device which has a USB WAN port. Check here to see how it works.
    • Provide 5G or LTE connectivity to your Windows or Linux devices on-the-go, acting as a cellular modem.
    Q. Is the MAX Adapter right for me?
    Are you in need of a solution that can add an additional 5G/LTE WAN to existing Peplink products via a USB WAN port, supports SpeedFusion VPN, offers external antenna support, has dual SIM slots, and is something small but not a full router? Then the MAX Adapter is for you!
    Q. Do antennas come included?
    Four LTE antennas are included but the GPS antenna must be purchased separately.
    Q. Can I pair my MAX Adapter with my Mac?
    Currently, our MAX Adapter is only compatible with Windows & Linux devices.
    Q. Does the MAX Adapter have a built-in battery?
    No, the MAX Adapter is powered via USB-C.
    Q. My MAX Transit has a USB port but it’s not compatible with the MAX Adapter. Why?
    The MAX Transit’s USB port only provides power input, not data. For compatibility, the device must contain a USB WAN port.
  • MAX Adapter (LTE)
    Product CodeCarrier/Category4G Bands 3G Bands
    MAX-ADP-LTEA-K-TGlobal
    CAT-12
    B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
    B18, B19, B20, B26, B28, B29, B30, B32,
    B41, B42, B43, B46, B48, B66
    HSPA+: B1, B2, B4, B5, B6, B8, B9,
    B19
    MAX-ADP-LTEA-R-TAmerica^
    CAT-12
    B14, B18, B19, B20, B26, B29, B30, B32,
    HSPA+: B1, B2, B4, B5, B6, B8, B9, B19
    MAX-ADP-LTEA-W-TGlobal
    CAT-6
    B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20,
    B25, B26, B29, B30, B41
    WCDMA/HSPA+/DC-HSPA+:
    B1, B2, B3, B4, B5, B8
    ^ US Carrier Certifications: AT&T, Verizon, FirstNet
    MAX Adapter (5G)
    Product CodeCarrier/Category5G Bands LTE Bands
    MAX-ADP-5GH-TGlobal / 5G*5G (NSA) Sub 6Ghz:
    n1, n2, n3, n5, n28, n41,
    n66, n71, n77, n78, n79
    B28, B29, B30, B32,B34, B38, B39,
    B40, B41, B42, B46, B48, B66, B71
    * US Carrier Certifications: AT&T, T-Mobile, US Cellular, Verizon (C-Band), FirstNet
  • Product CodeDescription
    ACW-232GPS Antenna *Not applied to MAX Adapter 5G
    SVL-MAX-ADP-LTEA-RK-1Y1-Year EssentialCare for MAX Adapter LTEA
    SVL-MAX-ADP-LTEA-RK-2Y2-Year EssentialCare for MAX Adapter LTEA
    SVL-MAX-ADP-5G-1Y1-Year EssentialCare for MAX Adapter 5G
    SVL-MAX-ADP-5G-2Y2-Year EssentialCare for MAX Adapter 5G
    ICS-0121-Year InControl 2 Subscription
    ICS-0242-Year InControl 2 Subscription
    ECP-A-1YEssentialCare+ A (1-Year), for LTEA (CAT-6)
    ECP-A-2YEssentialCare+ A (2-Year), for LTEA (CAT-6)
    ECP-A-4YEssentialCare+ A (4-Year), for LTEA (CAT-6)
    ECP-B-1YEssentialCare+ B (1-Year), for LTEA (CAT-12)
    ECP-B-2YEssentialCare+ B (2-Year), for LTEA (CAT-12)
    ECP-B-4YEssentialCare+ B (4-Year), for LTEA (CAT-12)
    ECP-D-1YEssentialCare+ D (1-Year), for 5G
    ECP-D-2YEssentialCare+ D (2-Year), for 5G
    ECP-D-4YEssentialCare+ D (4-Year), for 5G
  • MAX Adapter (LTE)
    • MAX Adapter
    • 2x LTE Antennas (ACW-813)
    • USB-C Female to USB-A Male Adapter
    • USB-C Power Cable
    MAX Adapter (5G)
    • MAX Adapter 5G
    • 4x LTE/5G LTE Antennas (ACW-235)
    • USB-C Power Cable
