Simultaneous Dual Band
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi on the AP One Rugged gives you two independent networks that work together, so all of your devices can connect without clashing.
Robust Metal Enclosure
Deploy your access point almost anywhere. The AP One Rugged is built with industrial-grade components that stand up to harsh environments and extreme temperatures.
Boost your Network
Increase your wireless speeds with AP One Rugged. Connect your devices with 11ac while enjoying industrial-grade reliability
Ease of Deployment
The 2-port switch allows the AP One Rugged to be dropped into any network transparently, without need for extra cabling.
User Access Control
Control network access with separate logins for Control network access with separate logins for each user group. AP One access points support up to 16 SSIDs, each with independent bandwidth limits and web blocking.
Wide Coverage
Get a strong signal and great coverage wherever you work. The AP One Rugged supports 2.4 GHz high-power Wi-Fi for wider range and better performance than ever.
Centralized Management
Configure AP One Rugged onsite or from the cloud. Our AP Controller lets you locally manage access points from your Balance router, while InControl 2 offers a complete cloud-based solution accessible from any web-browser.^
Social Wi-Fi Hotspot
Guests can now access your Wi-Fi hotspot with their Facebook login. In exchange, you can learn more about your customer base with insightful reports
Complete Network Solutions
Enjoy better network integration and performance. AP One access points are a perfect complement to Balance routers, together providing blazing speed and superior reliability across your entire network.
#PowerofPeplink
^ Requires Peplink Balance / Pepwave MAX Firmware 6.1.3 for AP Controller support on AP One Enterprise.
Ethernet Port 2x GE Wi-Fi Standard 802.11ac/a/n and 802.11b/g/n 3×3 MIMO
2.4GHz * 450Mbps 5GHz * 1300Mbps Simultaneous
2.4GHz and 5GHz
Yes Wi-Fi Transmit Power 2.4GHz: 24dBm / 17dBm (CE)
5GHz: 22dBm / 17dBm (CE)
Coverage (With line of sight in open environments) 680ft |
207m
Recommended Concurrent Users Per Radio 60 Number of SSID Per Radio 16 Antenna Type External Omni Antenna Gain 2.4GHz: 3dBi |
5GHz: 5dBi
Enclosure Ruggedized Metal Dimensions 5.8 x 4.6 x 1.6 inches |
147 x 115 x 40 mm
Weight 0.93 pounds |
420 grams
AC Adapter
AC Input 100V-240V
DC Output 12V, 2A
PoE Input 802.3af Power Consumption 13W (max.) Operating Temperature -40° – 149°F |
-40° – 65°C
Humidity 15% – 95% (non-condensing) Certifications FCC, CE, RoHS * The frequency range for 2.4GHz and 5GHz are 2412−2472 MHz and 5180−5825 MHz respectively.
Network Bridge Mode
Router (NAT) Mode
Wireless Distribution System (WDS on 2.4GHz Only)
Management VLAN (802.1p)
Spanning Tree Protocol (802.1d)
Radio Multiple SSID
Auto Channel Selection
Transmit Power Adjustment
Neighbour AP Detection
AP Security Open
WPA-PSK/RADIUS
WPA2-PSK/RADIUS
InControl Cloud Management
Peplink AP Controller
SNMP v1, v2c and v3
Client Management per SSID VLAN with QoS (802.1p/802.1q)
Bandwidth Control
MAC Address Filtering
Layer 2 Client Isolation
Limit on Max. Number of Client
Client Management per Client VLAN with RADIUS
VLAN with VLAN Pool
Bandwidth Control
Multicast Filter
IGMP Snooping/Multicast Enhancement
Complete PepVPN Solution Site-to-Site VPN
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
Captive Portal By InControl -
Product Code Description ACW-622 Includes 1x 56V Power Supply
Enables 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
- 1 x AP One Rugged
- 1 x 12V2A Power supply
- 3 x 5dBi Omni Antenna
Suitable For Product Name Product Code Description Indoor Desktop or Wall-Mount Installation. AP One Rugged APO-RUG Simultaneous 802.11ac/a/n 1300Mbps and 802.11b/g/n 450Mbps. External omni antennas included.
