Certified Toughness
In addition to rugged metal enclosure, the MAX on the GO is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
Electromagnetic Compatibility
(EN 61000)
![](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Quad-USB-Rugged-Mobile-Router-MAX-700-3.jpg/w=2560)
Unparalleled Modem Compatibility
Supports 250+ USB cellular modems from more than 100 carriers. Odds are, you can plug in and start surfing instantly. But if not, just connect your modem and turn on Remote Assistance – our engineers will get right to work on adding support for your modem.
Terminal Block for Secure Power Supply
MAX on the GO with MediaFast is equipped with a terminal block for secure installation in vehicles and other locations.
Built-in 4-Port GE Switch
The MAX on the GO includes a built-in 4-port GE LAN switch, reducing clutter and the need for extra equipment.
![Quad USB Rugged Mobile Router MAX 700 #5](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Quad-USB-Rugged-Mobile-Router-MAX-700-5.jpg/w=992)
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
