MSP
Create High Value-Added Solutions at Half the Cost
Peplink has a wide range of connectivity tools at your disposal, from wired and wireless routers, switches and access points with rich networking features, software features such as bandwidth bonding, failover, WAN optimization, load balancing and remote cloud management. Build solutions for any application and deliver cost effective solutions. Explore what we can do that others cannot.
What are your Challenges in MSP Connectivity?
Integration
MSPs often have to put together multiple vendors for a complete solution which will require more management and integration from MSPs.
Cost Management
MSPs increasingly operate with razor thin margins, which creates a limit to the services MSPs can offer their clients.
Addressing the Market
Enterprise workload is evolving from traditional office premises to mobile, remote places, in which MSPs are not fully equipped to face.
The Big Picture
Full Solution
Retail PoS System
VoIP
Vehicle Networking
MSPs can leverage FusionHub and InControl for full supervision and control. FusionSIM helps mix & match SIM resources, while InControl offers MSP-branded cloud management and InTouch.
The MAX BR1 Mini combines value and resiliency with SpeedFusion’s Hot Failover to ensure online connectivity and Wi-Fi for retail stores’ PoS systems. Securely housed in a sleek and ruggedized enclosure makes this device conveniently deployable.
The Balance 20X futureproofs office connectivity with its versatile FlexModule Mini slot that accepts all kinds of WAN technology. Paired together with a FusionHub, Smoothing fills connectivity gaps to ensure minimal latency and packet loss. This means never missing a frame or sentence in conference calls or VoIP applications.
The MAX BR1 Pro 5G features 5G connectivity, Wi-Fi 6, and GPS fleet management, housed in a sleek and rugged shell. Use SpeedFusion Traffic Steering to give priority to selected traffic such as SaaS applications to never experience downtime.
To build a more reliable network while on the move, SpeedFusion Connect LTE offers access to on-demand data and multiple networks under a single plan.
MSP-Friendly Business Model
Robust Devices
Quality products with robust software and housed in ruggedized hardware at unbeatable prices
MSP-Friendly License Model
MSP-friendly license model with fairly prices subscription and no device lock-in after subscription expires
Simple Billing
Offer one price to cover multiple years of management using a synchronized annual CarePlans billing cycle
Leverage on-demand 5G/LTE data from multiple carriers and offer it as a white-label service to clients
Featured Products
Balance 20X
  • FlexModule Mini slot caters to expandable modules
  • Embedded cellular model to back up xDSL
  • Enterprise-grade security and management
MAX BR1 Mini (HW3)
  • One-device connectivity solution
  • Versatile deployment options with Wi-Fi WAN
  • Plug-and-play functionality for convenient setup
MAX BR1 Pro 5G
  • GPS Fleet Management for large-scale tracking
  • Ignition sensing for reliability and efficiency
  • Slim form factor for compact and heated applications
SD-WAN Connectivity Solutions for Healthcare & Hospitals #8
InControl
InControl cloud-based endpoint management system enabling remote access to any Peplink device on your network. From a single screen, configurations can be pushed to any and all of your Peplink devices. InControl also generates useful reports on all aspects of your network, and can be integrated to your existing systems through API.
InTouch
Zero-Touch Remote Network Management Solution
InTouch is Peplink’s alternative to out-of-band management (OOBM). Instead of building separate networks or adding circuits dedicated to OOBM, InTouch integrates everything onto one platform for seamless connectivity. Use just one login to gain access to all remote devices behind your router – IP devices, remote desktops, remote protocols for servers, and more.
On-Demand LTE Connectivity
SpeedFusion Connect LTE houses both SpeedFusion Connect and Peplink’s very own on-demand LTE plan. This service allows users to pay only for what they need, reducing data wastage and multiple contracts for their Peplink devices.
