BR2 Micro
BR2 Micro
Micro Router, Mighty Connectivity
A tiny dual-cellular router that can fit
anywhere
Unbreakable cellular connectivity in the smallest footprint possible
Reliable routing that fits virtually anywhere
Smaller than a stack of 3 decks of cards, the BR2 Micro fits where no others can.
Instant Configurability
Built-in eSIM enables zero-touch provisioning, configuration and management.
Remote Device Management
Peplink InControl and InTouch eliminates the need for pre-staging configurations.
Ruggedized Metal Enclosure
with flexible, low power options
Cost-effective and Scalable for Mass Deployment
Port and Connections
