Fully Optimized for Telemetry
BR1 Mini Core
High Level of Security Compliance
Designed with strict security compliance in mind, we’ve tailor-made the device to exclude Wi-Fi & GPS functionality, making it great for networks that require a highly secure connection.
Full GPIO functionality
Seamlessly integrate telemetry devices into your network with the BR1 Mini Core’s built-in I/O functionality.
Power through AC/DC
Now available for purchase with DC cables, we aim to make it easy for our users to sync up all their devices with zero hassle.
Certified safe for work
With UL and Class 1 Division 2 certifications, among many others, the BR1 Mini Core is ready to handle demanding setups.
Ports and Connections
* Available with a feature pack add-on license.
WAN Link Health Check
Bandwidth Allowance Monitor
IPv6 SupportLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted Balance
-Priority
-Overflow
-Persistence
-Least Used
-Lowest Latency
-Enforced
-Fastest Response Time
SpeedFusion
– Site-to-Site VPN
– SpeedFusion Hot Failover^
– SpeedFusion WAN Smoothing^
– 256-bit AES Encryption
– Pre-shared Key Authentication
– Dynamic Routing
– PPTP VPN Server
– RADIUS, LDAP Authentication
IPsec VPN (Network-to-Network)@Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
Security 128-bit WEP
WPA & WPA 2
Stateful Firewall
DoS Prevention
Web Blocking
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Certifications FCC, CE *, RoHS
UL+CUL (62368-1) *
UL 121201 (Class I and Division 2) *Device Management Web Administrative Interface
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
^ Available with a feature pack add-on license.
* Certification pending
@ IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices. -
Product Code Embedded
Modem(s)Regions LTE Bands 3G Bands MAX-BR1-MINI-LTE-US-T-M-PRM 1x CAT-4 Primary: North America* B2, B4, B5, B12, B13, B14, B66, B71 WCDMA/HSPA+/DC-HSPA+: B2, B5 # US Carrier Certifications: AT&T, FirstNet, T-Mobile, Verizon
Regions are for reference only. For specific location compatibility, please refer to the bands.
Product Code
Description
PRM-MAX-BR1-MINI-1Y
1-Year PrimeCare for BR1 Mini Core
PRM-MAX-BR1-MINI-2Y
2-Year PrimeCare for BR1 Mini Core
PRM-MAX-BR1-MINI-4Y
4-Year PrimeCare for BR1 Mini Core
MAX-BR1-MINI-LC-FP
Feature pack for BR1 Mini Core enables Ethernet WAN, Hot Failover, WAN Smoothing
ACW-634
10ft DC Power Cable
ACW-DIN-BR1-MINI
DIN Rail Mount
ANT-MB-20G-S-B-6
2×2 MIMO 5G-Ready Cellular Antenna System with GPS Receiver (Black)
ANT-MB-20G-S-W-6
2×2 MIMO 5G-Ready Cellular Antenna System with GPS Receiver (White)
MAX BR1 Mini Core
- MAX BR1 Mini Core
- 2x LTE Antennas (ACW-342)
- 1x 12V 2A 4pin Power Supply (ACW-632)
