BR Pro Family
The New Benchmark for Professional Connectivity
Network Slicing
Options
Advanced 5G Performance
Powered by the X65 5G modem, both routers support standalone (SA) and non-standalone (NSA) 5G modes with enhanced carrier aggregation capabilities, delivering increased throughput and faster speeds across public and private 5G networks.
(On sub-6 GHz 5G)
Streamlined, Flexible Deployment with PoE Power Input
Power over Ethernet (PoE) input simplifies installation and cabling, allowing the BR1 to be placed in locations with better signal reception, without needing a nearby power outlet.
Smarter Operations with Edge Computing
Run custom applications directly on the device with built-in Docker support and onboard storage, enabling agile performance, seamless integration, and streamlined deployment and management.
Government-Ready: TAA Compliant
Meet federal and government requirements with full TAA compliance for secure and regulated deployments.
Priority for Public Safety
Ideal for public safety environments, both routers carry AT&T FirstNet and T-Mobile T-Priority certifications and are Verizon Frontline verified, ensuring prioritized and reliable connectivity during mission-critical operations.
Flexible SIM Choices for Any Situation
Use eSIM for greater efficiency and instant connectivity, with the option to use physical SIMs when needed.
Seamless Failover for Starlink, Fiber, and FWA
Seamlessly integrate 5G with Starlink, fiber, and fixed wireless access (FWA) through SpeedFusion to deliver uninterrupted connectivity. Stay reliably online, always.
Ports and Connections
BR2 Pro (5GK)
BR1 Pro (5GK)
