360° Hardware View
An All-in-One Solution for Unbreakable Enterprise Branch Networks
Combine high-speed, resilient connectivity with the power of an entire branch infrastructure in a single chassis. The Balance 310 5G is purpose-built for enterprises where downtime isn't an option. Built-in 5G failover ensures business continuity, while a consolidated platform translates to faster deployments and zero vendor complexity. With redundant WAN paths and dual power inputs, you eliminate single points of failure across your connectivity and power.
Global, Expandable, and Reliable Enterprise 5G
Featuring a global 5G modem with flexible SIM support, the Balance 310 5G provides compatibility across carriers worldwide and enables streamlined global deployments. For scalable cellular expansion, simply add the 5G Adapter or 5G Dongle as needed. Hot Failover ensures seamless backup across all 5G connections, preventing any disruption to your business operations.
Any WAN, Uninterrupted Operations
Unify diverse WAN technologies into a single, resilient network. The Balance 310 5G allows you to bond, failover, or smooth traffic across multiple connections to maximize uptime and application performance. Maintain reliable connectivity for mission-critical operations even during link failures or degraded network conditions.
Fiber Broadband
Wi-Fi WAN
Built-in
Fixed Wireless Access
LEO Satellites
GEO Satellites
Centralized Branch Power and Connectivity
Simplify your branch setup by powering critical peripherals directly from the router. With eight PoE+ LAN ports, the Balance 310 5G effortlessly drives local devices, such as IP cameras and access points, without separate power supplies or external switches. This unified setup maximizes space efficiency, eliminates cable clutter, and streamlines local network management.
Industrial-Grade Design & Operational Efficiency
A fanless chassis, wide operating temperature range (-40°F to 149°F / -40°C to 65°C), dual power inputs, and built-in GPS enable reliable deployment across fixed, mobile, and industrial environments. A single standardized hardware platform simplifies global logistics, reduces sparing requirements, and lowers long-term operational overhead.
FIPS 140-3 Validated
Edge Intelligence
Native Docker support and 8GB of internal storage enable applications, including monitoring agents, security services, and network automation tools, to run directly on the router. By hosting services at the edge, organizations can reduce reliance on dedicated on-site PCs or servers, minimizing infrastructure footprint while lowering power and maintenance requirements.
1. 10G is backward compatible with FE / GE / 2.5G / 5G; 2.5G is backward compatible with GE and FE.
2. SFP+ port is a configurable WAN/LAN port. WAN/LAN Port Configuration is changeable on the Web Admin.
| Software | Peplink Balance Firmware |
| WAN | Support for PPPoE, Static IP, DHCP WAN Link Health Check PING DNS Lookup HTTP Bandwidth Allowance Monitor IPv6 Passthrough Support USB 5G/4G/3G Modem Support Support for Dynamic DNS services changeip.com dyndns.org no-ip.org tzo.com DNS-O-Matic WAN Port Convertible into LAN Port |
| Load Balancing | Intelligent Failover Session Persistence Per-Service Load Distribution Multiple Algorithms - Weighted - Enforced - Persistence - Priority - Overflow - Least Used - Lowest Latency |
| Security | DoS Prevention Stateful Firewall Web Blocking |
| Complete VPN Solution | SpeedFusion VPN/SpeedFusion Bandwidth Bonding - Site-to-Site VPN - Bandwidth Aggregation - Hot Failover - 256-bit AES Encryption - Pre-shared Key Authentication - Dynamic Routing - X.509 Certificate Support PPTP/L2TP/OpenVPN Server - Local User, LDAP, RADIUS, Active Directory Authentication IPsec VPN (Network-to-Network) - X.509 Certificate Support GRE Tunnel (Network-to-Network) |
| Advanced QoS | User Groups - Bandwidth Reservation - Individual Bandwidth Limit Application Prioritization - By User Groups - SIP, HTTPS, VPN QoS - Custom Application QoS |
| Networking | NAT and IP Forwarding Static Routes Port Forwarding Many to One, One to One NAT NAT Pool SIP ALG, H.323 ALG UPnP, NAT-PMP BGP, OSPFv2 and RIPv2 Support Bonjour Forwarding |
| AP Controller | Support for Pepwave AP Series Auto AP Discovery Auto AP Firmware Management AP Profile Configuration Wi-Fi Usage Statistics |
| Captive Portal | Support for Wired and Wireless LAN Clients Support RADIUS Authentication Support LDAP Authentication Time and Usage Quotas on Open Access Mode Built-in Customizable Splash Page |
| DNS | Built-in Authoritative DNS - Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records |
| Device Management | Web Administrative Interface Command Line Interface InControl Cloud Management Email Notification Active Client & Session Lists Bandwidth Usage Statistics Syslog Service SNMP v1, v2c and v3 |
| Product Code | Embedded Modem | Region | 5G Bands | LTE Bands |
| BPL-310-5GK-T-PRM | 1x 5G | Global* *US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet | 5G (NSA & SA) Sub 6Ghz: n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n71, n75, n76, n77, n78, n79 | B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 |
| PRM-G-1Y | PrimeCare G (1-Year) |
| PRM-G-2Y | PrimeCare G (2-Year) |
| PRM-G-4Y | PrimeCare G (4-Year) |
| PCP-G-1Y | PrimeCare+ G (1-Year) |
| PCP-G-2Y | PrimeCare+ G (2-Year) |
| PCP-G-4Y | PrimeCare+ G (4-Year) |
| ANT-MB-42G-S-B-6 | Mobility 42G - 4x4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (Black) |
| ANT-MB-42G-S-W-6 | Mobility 42G - 4x4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (White) |
| ACW-678 | 54V 5.19A Power Supply |
| ACW-996 | 1U Metal Rack Kit for Half-Rack Devices |
| 1x Balance 310 5G |
| 1x 54V 5.19A Power Supply (ACW-678) |
| 4x LTE/5G Antennas |
| 2x Wi-Fi Dual Band Antennas |
| 1x GPS Active Antenna |
| 1x Mounting Bracket Kit with screws |
| 1x Rubber Foot Pad Set |
