Intelligent Outbound Policy
Optimize your network traffic for various scenarios with smart, adaptive policies.
SpeedFusion Tunnel
Maintain clear, uninterrupted communication.
SFP+ Port with Fiber Link
Get the speed you need without compromising other applications.
Load Balancing Algorithms
Increase efficiency by ensuring important applications are prioritized.
Edge Computing with Intelligent
Bandwidth Management
512G Storage
Run KVM and Docker for efficient local data processing.
Prefetch & Off-Peak Downloads
Maximize network efficiency by leveraging storage to perform prefetching and schedule downloads during off-peak hours.
Unlock Ultimate WAN Speed
Squeeze the most out of your 10G high-speed Fiber WAN with a single, robust device.
8x 10G Fiber ports
Stay Connected.
Stay Unbreakable.
Sub-second resiliency is what you need in the enterprise environment.
High Availability mode
Dual Redundant Hot-Swappable PSUs
Network Control at Your Fingertips
Take full control of your network with InControl 2 – a centralized management platform for both core and off-site networks
Real-Time Monitoring and Automatic Reporting Analysis
Stay ahead of potential downtime with real-time monitoring and automated reports.
Switch / AP Controller
Simplify network management by managing your switches and access points through a single, user-friendly interface.
Ports and Connections
1. SFP+ port 1-8, Ethernet WAN port 1-4, Ethernet LAN port 1-4 are configurable WAN/LAN ports. WAN/LAN Port Configuration is changeable on the Web Admin. Specifications are subject to change without notice.
Software Peplink Balance Firmware WAN Support for PPPoE, Static IP, DHCP
WAN Link Health Check
PING
DNS Lookup
HTTP
Bandwidth Allowance Monitor
IPv6 Support
USB 4G/3G Modem Support
changeip.com
dyndns.org
no-ip.org
tzo.com
DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
Security DoS Prevention
Stateful Firewall
Web Blocking
Complete VPN Solution SpeedFusion VPN/SpeedFusion Bandwidth Bonding
-Site-to-Site VPN
-Bandwidth Aggregation
-Hot Failover
-256-bit AES Encryption
-Dynamic Routing
-X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Advanced QoS User Groups
-Bandwidth Reservation
-Individual Bandwidth Limit
Application Prioritization
-By User Groups
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
BGP, OSPFv2 and RIPv2 Support
Bonjour Forwarding
AP Controller Support for Peplink AP Series
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Support RADIUS Authentication
Support LDAP Authentication
DNS Built-in Authoritative DNS
-Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Power Requirements Universal Input 100V – 240V AC -
Product Code Product Name BPL-1350-EC-PRM Balance 1350 EC -
Product Code
Description
PRM-P-1Y
PrimeCare P (1-Year)
PRM-P-2Y
PrimeCare P (2-Year)
PRM-P-4Y
PrimeCare P (4-Year) PCP-P-1Y
PrimeCare+ P (1-Year) PCP-P-2Y
PrimeCare+ P (2-Year) PCP-P-4Y
PrimeCare+ P (4-Year) -
- 1x Balance 1350 EC
- 4x Rubber Foots
- 1x Ear Rack Mount Kit with screws
- 2x Power Cords
