Super Rugged and Wi-Fi 6 Ready
Built like a Tank
An IP67 enclosure provides a solid exterior to protect not only the device, but your connection as well.
Enterprise-Grade Roaming Speeds
Bring in an unbreakable connection wherever you need it. Experience the speed of an office network even while you’re on the field.
Mesh Capability
With Wi-Fi mesh support, have the flexibility to deploy the device wherever it’s needed and eliminate all the blindspots in your network.
Turnkey Captive Portals
Captive portals are simple to create and easy to customize. Implement a guest network with just a few clicks.
Seamless Integration within Peplink’s Ecosystem
Built for use in the Peplink Ecosystem, link up the new access point to the rest of your Peplink network for instant connectivity.
Perfect for Demanding Deployments
Provide Wi-Fi 6 connections to factories, construction sites or harbor sides. No matter the weather, no matter the conditions.
Ports and Connections
Built like a Tank
Mesh Capability
Network Bridge Mode
Router (NAT) Mode
Wireless Distribution System (WDS on 2.4GHz Only)
Management VLAN (802.1p)
Spanning Tree Protocol (802.1d)
Radio Multiple SSID
Auto Channel Selection
Transmit Power Adjustment
Neighbor AP Detection
AP Security Open
WPA/WPA2/WPA3-Personal
WPA/WPA2-EnterpriseDevice Management Web Administrative Interface
InControl Cloud Management
Peplink AP Controller
SNMP v1, v2c and v3
Client Management Multicast Filter
IGMP Snooping/Multicast EnhancemenClient Management per SSID VLAN with QoS (802.1p/802.1q)
Bandwidth Control
MAC Address Filtering
Layer 2 Client Isolation
Limit on Max. Number of Client
Client Management per Client VLAN with RADIUS
VLAN with VLAN Pool
Bandwidth Control
Complete VPN Solution SpeedFusion VPN Site-to-Site VPN
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
Captive Portal By InControl
By Peplink AP Controller
Power Requirements 12V DC
Product Code Description APP-AX-IP67 2 x 2 MU-MIMO Wi-Fi 6 AP, Simultaneous Dual-Band 802.11a/b/g/n/ac/ax,
Industrial-grade in a waterproof and dust-tight IP67 outdoor enclosure. -
Product Code Description ACW-107 802.3af/at PoE Injector. Compatible with AP One AX Series and AP Pro Series ACW-825 2.4GHz & 5GHz Outdoor Wi-Fi Antenna Kit include 2x 2.4GHz and 2x 5GHz Outdoor Wi-Fi Omni Antenna (2x ACW-202 & 2x ACW-308)
ECP-D-1Y EssentialCare+ D (1-Year) ECP-D-2Y EssentialCare+ D (2-Year) ECP-D-4Y EssentialCare+ D (4-Year) -
AP Pro AX
- AP Pro AX
- 1x Water Proof M25 Ethernet cable gland
- 1x Mounting kit
- 1x M6 screw set
- 1x Wall screw with anchor set
