Why incorporate SpeedFusion Connect into your connectivity?
SFC Locations
Supported Models
Require firmware 8.1.0 or above
Enterprise Routers
Balance | SDX | EPX
Enterprise Mobility
HD | Dome | MBX | PDX
Mobile Routers
BR | Transit | UBR
Soho Routers
Soho | B One
Others
SFE
SpeedFusion Connect Usage Plans
Unlimited Plans
SFC-CLD-U-1M
SFC-CLD-U-1Y
Regular Plans
Purchase / Top Up
All pricing applies to US region only, other regions may vary
Please also refer to our SFC Usage Plan & Peplink eSIM Data Plan Terms and Conditions.
SpeedFusion Connect Usage Plan Quota
All Peplink routers with active CarePlan subscriptions can enjoy yearly SFC usage quota. The amount of quota depends on the tier of the routers. All tier plans can achieve up to speed of 200 Mbps ^. After exceeding the SFC usage limit, you can still use the service at a lower speed of 10 Mbps. *
^ The regular plans can go up to speed of 200Mbps. If you prefer higher performance, subscribe unlimited SFC Usage Plan (SKU: SFC-CLD-U-1M or SFC-CLD-U-1Y) which allows for speed of up to 400Mbps.
* Capped the speed at 10Mbps to ensure applications like remote desktops, Google Meet, MS teams, and Zoom can run smoothly while preventing extreme abuse of the service.
Frequently Asked Questions
Q1
What is SpeedFusion Connect (previously known as SpeedFusion Cloud)?
SpeedFusion Connect is Peplink’s infrastructure that provides access to a global network of SpeedFusion endpoints and technology without requiring additional hardware.
Q2
Can I purchase one SpeedFusion Connect plan and leverage it over multiple Peplink devices?
No, each SpeedFusion Connect plan is attached to a single device’s serial number. Each device must have its own plan in order to utilize SpeedFusion Connect.
Q3
How do I activate the SpeedFusion Connect allowance that’s included with my Care plan?
All Care plans now come with SpeedFusion Connect included. This data allowance will automatically begin and end in accordance with your warranty. No activation is required.
Q4
Can I activate SpeedFusion Connect once and link multiple Peplink devices to it?
Yes you can, the SpeedFusion Connect does not count towards your device’s peer limit.
Q5
Does SpeedFusion Connect count towards my SpeedFusion peer limit?
No, it does not.
Q6
My plan has expired but I still have usage left. What happens? Will it rollover?
Any remaining usage from expired plans will not be carried forward.
Q7
Can I track and monitor my SpeedFusion Connect usage?
Yes, keep track of your usage via the dashboards of your router’s WebUI.
Q8
How are SpeedFusion endpoints allocated?
An option to either manually choose your endpoint or automatically be assigned an endpoint is available. Click to learn more here.
Q9
How do I ensure the application that I want to protect uses SpeedFusion Connect?
You can use an outbound policy to ensure that traffic from a specific application goes through SpeedFusion Connect. Define your source traffic as “any” and select your application under “protocol”. Select “enforced” as your algorithm, and finally, select the SpeedFusion Connect as the enforced connection.
Q10
If I purchase multiple plans will the validity of the plans accumulate?
The maximum validity is 3 years. For example, If you buy 2x SFC-CLD-F plans at the same time, which has a 3-year validity per plan, the maximum expiry will still be 3 years.
Q11
I have activated “Auto-Renewal” in eStore. When will my subscription Auto-Renew?
By default, the preset trigger is set at 7 days prior to expiry or 10% data remaining, whichever comes first. Click to learn more here.
Q12
Does utilizing SpeedFusion Connect require special firmware?
Yes, all compatible models are required to have firmware version 8.1.0 or higher to utilize this service.
Still need help?
Submit your question to our Forum here.
