Gold and amber abstract graphic used as hero section background.
Firmware 8.6.0
Firmware 8.6.0 introduces new features and enhancements across SpeedFusion, security, satellite integration, and eSIM management. From improving WAN performance to expanding deployment flexibility, this release helps you build more reliable and manageable networks.
Faster SpeedFusion
SpeedFusion Boost
High performance shouldn't depend on perfect network conditions. A new addition to SpeedFusion, SpeedFusion Boost improves throughput across bonded WAN connections by preventing unstable links from dragging down overall performance. Even when individual connections within a SpeedFusion tunnel are affected by satellite handovers, temporary obstructions, network congestion, or adverse weather, these disruptions have less impact on overall bonded WAN performance.
Supported Devices
Diagram showing satellite connections bonding through SpeedFusion Boost.
B One Series
B One / B One Plus / B One 5G
Balance Series
Balance Two / Balance 20X / Balance 310 HW5 / Balance 310 5G / Balance 310 Fiber 5G / Balance 305 HW2 / Balance 310X / Balance 380 HW6 / Balance 380X / Balance 580 HW2,3 / Balance 580X / Balance 710 / Balance 1350 / Balance 1350 EC / Balance 2500 / Balance 2500 EC / Balance 5000 EC
BR Series
BR1 IP55 HW4 / BR1 Mini M2M / BR1 Mini HW3 / BR1 Mini 5G / BR1 Mini Core HW3 / BR1 Pro (CAT-20) HW7 / BR1 Pro 5G / BR2 HW4 / BR2 Micro / BR2 Pro HW4
Dome Series
Dome Pro Duo / Dome Pro LR / HD1 Dome Pro
FusionHub
FusionHub
MediaFast Series
MediaFast 500 / MediaFast 750
Orbit Series
MAX Orbit 2 / MAX Orbit 4 / MAX Orbit 8
Transit Series
Transit Duo Pro / Transit Pro E HW2
UBR Series
UBR Plus
X Series
EPX / MBX / MBX Mini / PDX / SDX / SDX Pro
A Scoreboard that Matters
SpeedFusion Score
A standard for measuring network quality, turning insights into action. Starting with Firmware 8.6.0, SpeedFusion Score is available in InControl for supported devices. It continuously evaluates network health using metrics such as latency, jitter, and packet delivery, presenting the results as a single, easy-to-understand score. Use these real-time insights to quickly identify performance gaps, optimize your network, and keep it performing at its best.
Supported Devices
SpeedFusion Score dashboard showing an excellent connection quality score of 350 with bonded speed of 1 Gbps.
B One Series
Balance Series
BR Series
Dome Series
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
Enhanced Security
FIPS 140-3 Validated Mode on Supported Devices
Deploy confidently across regulated environments. FIPS Mode is now a standard feature on supported devices, providing ongoing access to FIPS 140-3 validated security for deployments with strict security and compliance requirements.
Supported Devices
Grid of Peplink router back panels with FIPS 140-3 certification badge.
WireGuard Support for Remote User Access
Flexible, modern connectivity for remote users. WireGuard is now supported for remote user access, expanding secure remote access options with a lightweight and widely adopted VPN protocol.
Supported Devices
Peplink InControl remote user access settings with WireGuard VPN option selected.
RADIUS over TLS (RadSec) Support
Secure authentication for enterprise Wi-Fi deployments. Now supported on Peplink Wi-Fi access points, RadSec strengthens RADIUS authentication security by encrypting traffic over TLS, reducing the risk of credential interception.
Supported Devices
Diagram of Wi-Fi clients connecting through a Peplink router to a RADIUS server via RadSec.
Secure DNS - Powered by Cloudflare
Encrypt DNS traffic to strengthen network security. Enable Cloudflare-powered secure DNS in InControl for devices with an active Care Plan. Encrypt DNS queries with DNS over HTTPS (DoH) and block malicious domains.
Supported Devices
Diagram of encrypted DNS queries between a Peplink router and Cloudflare, shown with InControl Secure DNS settings.
Balance Series
Balance Two / Balance 310 HW5 / Balance 310 5G / Balance 310 Fiber 5G / Balance 305 HW2 / Balance 310X / Balance 380 HW6 / Balance 380X / Balance 580 HW2,3 / Balance 580X / Balance 710 / Balance 1350 / Balance 1350 EC / Balance 2500 / Balance 2500 EC / Balance 5000 EC
BR Series
BR1 IP55 HW4 / BR1 Pro (CAT-20) HW7 / BR1 Pro 5G / BR2 Pro HW4
Dome Series
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
FusionHub
FusionHub
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
Balance 20X / Balance 310 Fiber 5G
BR Series
BR1 IP55 HW4 / BR1 Mini M2M / BR1 Mini HW3 / BR1 Mini 5G / BR1 Pro (CAT-20) HW7 / BR1 Pro 5G / BR2 HW4 / BR2 Pro HW4
Dome Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
Starlink Integration
Starlink WAN Health Check Optimization
Prevent false failovers on Starlink connections. Starlink health checks now use stable public endpoints, improving monitoring accuracy and reducing unnecessary WAN switching in enterprise deployments.
Supported Devices
Diagram of Starlink WAN health check using DNS servers on a Peplink router dashboard.
B One Series
Balance Series
BR Series
Dome Series
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
Additional Enhancements
Enhanced eSIM Support
Icon of an eSIM chip with four profile slots.
4 eSIM Profiles Per Module
Store up to four eSIM profiles on each cellular module for greater carrier flexibility across different deployment scenarios.
Supported Devices
GSMA compliant certification badge.
GSMA eSIM Profile Compatibility
Expanded compatibility with GSMA-compliant eSIM profiles, unlocking more options when sourcing eSIM services.
Supported Devices
Peplink dashboard showing Synergy WAN connected via BYO eSIM to AT&T.
Better BYO eSIM Visibility
Bring Your Own (BYO) eSIM information is now displayed when operating in Synergy Mode, improving visibility and management of third-party eSIM profiles.
Supported Devices
Peplink dashboard displaying active carrier name for a cellular eSIM connection.
Peplink eSIM Carrier Name Display
Active carrier names are now shown for Peplink eSIM data plan connections, making network identification easier during deployment and troubleshooting.
Supported Devices
Network & Wireless Management
Peplink SSID settings with metered connections enabled and low data mode active.
Wi-Fi Metered Networks
Help compatible devices reduce unnecessary background data usage.
Supported Devices
Diagram of a Peplink Synergy Controller managing an access point on a synergized device.
Extended Synergy Mode with AP Management
Access and manage APs on Synergized Devices from a single interface.
Supported Devices
Peplink AP profile settings showing 6 GHz band configuration with Wi-Fi 7 branding.
Enhanced AP Controller
Manage 6 GHz settings for connected Wi-Fi 7 APs from the router interface.
Supported Devices
Peplink controller status showing wireless clients labeled with PPSK names.
PPSK (Private Pre-Shared Key) Name Display
Identify which PPSK each wireless client is using at a glance.
Supported Devices
Traffic & Performance
Peplink WAN connection settings with upload and download bandwidth limits enabled.
Per-WAN Bandwidth Limiting
Apply upload and download limits to individual WAN connections.
Supported Devices
Peplink LAN port settings with jumbo frame option enabled.
Jumbo Frame Support
Improve efficiency for large data transfers on compatible networks.
Supported Devices
Device Management
Diagram showing digital input triggering a factory reset on a Peplink router.
GPIO-Triggered Emergency Reset
Enable instant factory resets for high-security deployments.
Supported Devices
OneWeb Visibility
Peplink dashboard showing WAN 1 connected via OneWeb with connection details expanded.
Centralized monitoring for OneWeb networks
OneWeb terminal status and operational metrics are now integrated into the InControl WAN dashboard, enabling real-time visibility for enterprise network management.
Supported Devices
B One Series
Balance Series
Balance 20X / Balance 310 Fiber 5G / Balance 310X
BR Series
Dome Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
Synergized Device & Wi‑Fi 6
B One Series
BR Series
Dome Series
Orbit Series
Transit Series
Synergy Controller
B One Series
Balance Series
BR Series
Dome Series
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Balance Series
BR Series
Dome Series
FusionHub
FusionHub
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
B One Series
Dome Series
Transit Series
B One Series
Balance Series
Balance 310
BR Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
MBX / MBX Mini
B One Series
Balance Series
BR Series
Dome Series
FusionHub
FusionHub
MediaFast Series
Orbit Series
Transit Series
UBR Series
UBR Plus
X Series
Ready to Upgrade?
Get the latest features and enhancements with Firmware 8.6.0.
