PDX
Portable, Rapidly Deployable SD-WAN
The PDX has a quad-cellular router, antennas, and batteries all seamlessly integrated into a rugged enclosure. If you want more cellular connections and frequencies, the PDX can also integrate SpeedFusion Engines.
Portable,Instantly Deployable Industrial-Grade SD-WAN Router PDX #2
Instantly Connect from Anywhere
Redundant SIM Slots
Quad Cellular Modems and Redundant SIM slots allow you to use up to four different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Built Tough
Rated at 7.7G vibration resistance by the military MIL-STD-810H standard. Wide -40° – 113°F (-40° – 45°C) Temperature range.
Battery Powered
The PDX has internal batteries, so it can operate independently for up to 9 hours.
Portable,Instantly Deployable Industrial-Grade SD-WAN Router PDX #4
Traffic Steering
Apply different SpeedFusion VPN technologies to traffic from different applications. Apply Hot Failover to ERP traffic while applying WAN Smoothing to VoIP and Videoconferencing.
Portable,Instantly Deployable Industrial-Grade SD-WAN Router PDX #5
Instant Connectivity for Temporary Sites
The PDX provides you with instantly deployable connectivity, available right when the first boots hit the ground. By combining the bandwidth of up to 4x Gigabit LTE connections, you can perform fast and reliable connectivity no matter where the site is located. Quickly and safely transmit project data, emails, plans, and blueprints between personnel, sites, and headquarters.
Portable,Instantly Deployable Industrial-Grade SD-WAN Router PDX #6
Event Live Streaming and Connectivity
Keep your event connected and your cameras streaming. With support for 4x Gigabit LTE connections, the PDX can keep your event connected no matter where it is held. The PDX has 8x 802.3at PoE ports, so you can simplify your cabling when connecting and powering your devices. It can also deliver 802.11ac Wi-Fi which supports a customizable captive portal with advertisements.
Portable,Instantly Deployable Industrial-Grade SD-WAN Router PDX #7
PDX is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform. Setup SpeedFusion networks, make bulk configuration changes, determine Firmware policy, build a custom captive portal. Do all this and more remotely using the InControl2.
  • WAN Interface2x GE Ports*
    4x Embedded LTE-A Modems with Redundant SIM Slots
    LAN Interface7x GE Ports*
    Wi-Fi Interface802.11ac/a/b/g/n, 1166 Mbps 2×2 MIMO Wi-Fi WAN and/or AP Simultaneous Dual-Band
    PDX Throughput2.5 Gbps
    PepVPN Throughput (No Encryption) | (256-bit AES)600 Mbps | 500 Mbps
    Recommended Users50-500
    LTE-A Pro ModemsDownlink/Uplink Per Modem:
    600 Mbps/150 Mbps
    Cellular and GPS Antennas8x Cellular Antennas (Embedded)
    1x GPS Antenna (Embedded)
    4x Wi-Fi Antennas (Embedded)
    Power InputDC: 12V – 56V, AC: 100V – 240V
    Power OutputUp to 7x 802.3af PoE, 1x USB Power Outputs
    Power Consumption38W (max.)
    Dimensions19.7 x 14.8 x 7.7 inches |
    500 x 375 x 195 mm
    Weight28.7 pounds | 13 kg
    Operating Temperature-40° – 113°F |
    -40° – 45°C
    CertificationsFCC, IC, CE,
    7.7G Vibration resistance, MIL-STD-810H 514.8E-1 Cat24, IP55/65^, [email protected], FirstNet%
    Warranty1-Year Limited Warranty
    * 2x GE port is configured as a LAN port by default, configuration is changeable on the Web Admin. ^ IP55 certified. IP65 certification testing in progress.
    @ Certification Pending.
    % Tests completed, under FirstNet final review.
  • WANSupport for PPPoE, Static IP, DHCP
    WAN Link Health Check
    -PING
    -DNS Lookup
    -HTTP
    Bandwidth Allowance Monitor
    IPv6 Support
    USB 4G/3G Modem Support
    -changeip.com
    -dyndns.org
    -no-ip.org
    -tzo.com
    -DNS-O-Matic
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    -Weighted
    -Enforced
    -Persistence
    -Priority
    -Overflow
    -Least Used
    -Lowest Latency
    SecurityDoS Prevention
    Stateful Firewall
    Web Blocking
    Web Filtering Blacklist
    Complete VPN SolutionPepVPN
    -Site-to-Site VPN
    -Bandwidth Bonding
    -Hot Failover
    -256-bit AES Encryption
    -Dynamic Routing
    PPTP/L2TP/OpenVPN Server
    -X.509 Certificate Support
    Advanced QoS User Groups
    -Bandwidth Reservation
    -Individual Bandwidth Limit
    Application Prioritization
    -By User Groups
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA Support
    BGP, OSPFv2 and RIPv2 Support
    AP Controller Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Power RequirementsDC Jack: 12V – 56V
    • PDX
    • 1x Special Power Cord for PDX
    • 1x Special Card Plug for PDX
    Product Code
    Description
    PDX-BAT-KIT     Pepwave PDX Battery Kit, 1x Metal Clamp, 1x Power Cable, 2x M3 Scr, 98Wh, 14.4V
    SFE-PDX-KIT
    SpeedFusion Engine Duo Accessory Kit for PDX
  • Product CodeCarrier/RegionEmbedded Modems4G Bands3G Bands
    PDX-LTEA-R-TAmerica / CAT-124B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14 , B18, B19, B20, B26, B29, B30, B32, B41, B42, B43, B46, B48, B66B1, B2, B4, B5, B6, B8, B9, B19
    PDX-LTEA-K-TGlobal / CAT-124B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19, B20, B26, B28 , B29, B30, B32, B41, B42, B43, B46, B48, B66B1, B2, B4, B5, B6, B8, B9, B19
