Future Proof Design
The EPX supports a FlexModule, enabling you to customize the platform with your choice of ports, as well as instantly apply new technology as it will be released and available.
Peplink team will build additional FlexModules as new technologies such as 5G emerge. Simply insert the new FlexModule and the EPX will become 5G ready; no need to purchase a new device.
Compatible With:
Modular Platform. Game Changer
4000 VPN Peers
30 Gbps Throughput
20 000 Users
Gigabit Bandwidth On-The-Go
In its cellular configuration, the EPX is the most powerful wireless SD-WAN router in the industry. It can combine the bandwidth of up to 18 connections, supporting 36 SIM cards and providing gigabits of bandwidth on-the-go.
Different Cellular Configurations with Expansion Modules
Use Cases
Commercial LTE & Public Safety LTE
SD – WAN Backhaul
Cellular Backup for Branches
Work Sites
Combined Public & Commercial Safety LTE
Equipped with an EPX, mobile headquarters can combine private LTE, commercial LTE & satellite links to form fast and unbreakable VPN connection both to mobile HQ and to patrol vehicles. With this configuration, patrol vehicles benefit from increased cellular coverage. Even if they are outside the range of one cellular provider, they will still be within the range of others.
SD-WAN Backhaul for ISP
Whether providing Internet service with a SLA, or building a video surveillance streaming network, ensuring service continuity is crucial. The EPX enables service providers to build a flexible SD-WAN backhaul to the main network, incorporating as many Ethernet, Fiber, and cellular links as needed to provide fast and solid connectivity.
Cellular Backup for Regional Offices
With its modular architecture, the EPX enables regional offices to add WAN connections of any type as they grow in size. With the ability to add cellular modules, the EPX also provides as much cellular connectivity as needed for the company network to operate at full speed even if land lines lose connectivity.
Work Sites and Events
With the EPX, temporary sites could get connected in minutes. The EPX can combine up to 18 cellular connections for high-definition video streaming and high-volume data transfers. The EPX can also host docker containers, giving you the ability to host your own custom apps onsite to simplify management.
#PowerOfPeplink
Power Input AC Input 100V – 240V Power Consumption 215W* Throughput # 30Gbps PepVPN Throughput (No Encryption ) | (256-bit AES) 4Gbps | 2Gbps Recommended Users 5000-20000+ Max. PepVPN/SpeedFusion Peers 4000 Dimensions 18.9 x 21.7 x 3.6 inches | 480 x 550 x 90 mm Weight (No Modules) 31.3 pounds | 14.2 kilograms Operating Temperature 32° – 113°F (0° – 45°C) Humidity 5% – 90% (non-condensing) Certifications FCC, IC, CE-RED
EN 50155: Railway Applications
EN 61373:1999 IEC 61373:1999 : Shock and Vibration Resistance
EN 50121: Rolling Stock EMC, Signalling and Telecom Apparatus
Warranty 1-Year Limited Warranty * 200W consumption for the main chassis, 15W consumption for the optional LCD module.
# Router Throughput and PepVPN/SpeedFusion Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments. Figures apply to the latest hardware revision. The throughput result is tested with DHCP/Static IP WAN. -
8x GE PoE Module (EXM-8C) Interface 8x 10/100/1000M Ethernet Ports *
Capable of PoE+Power Consumption 15W (255W max. with 802.3at/af PoE+ Output) Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 1.1 pounds | 475 grams
* Module can be configured with LAN or WAN ports as needed
4x SFP+ Module (EXM-4F) Interface 4x SFP+ Ports * Power Consumption 11W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 0.83 pounds | 375 grams
SIM Injector FlexModule (EXM-SIM-BK56) SIM Slot Capacity 56 4FF Nano SIM Cards Power Consumption 15W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 1.30 pounds | 600 grams Compatible with EPX, SDX Pro
3x LTE-A Module (EXM-3LTEA) Interface 3x Embedded LTE-A Cellular Modems
with Redundant SIM Slots
Antenna Connectors 6x SMA Cellular Antenna Connectors
1x SMA GPS Antenna Connector
Downlink/Uplink Datarate 300Mbps/50Mbps (CAT-6)
600Mbps/150Mbps (CAT-12)
Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
CAT-18. 2x LTE-A Module (EXM-2GLTE-G) Interface 2x Embedded LTE-A Cellular Modems
with Redundant 4FF Nano SIM SlotsAntenna Connectors 8x SMA Cellular Antenna Connectors
Downlink/Uplink Datarate 1.2Gbps/150Mbps Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
2x 5G Module (EXM-2X5G) Interface 2x Embedded Cellular Modems
1x SMA GPS Antenna ConnectorDownlink/Uplink Datarate 5G: 4 Gbps / 700 Mbps
LTE CAT-20: 2 Gbps / 150 MbpsPower Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
1x LTE-A Pro Module, 1x 5G Module (EXM-1X5G-1GLTE-G) Interface 1x Embedded 5G/4G/3G Multi-mode Modems
1x SMA GPS Antenna ConnectorDownlink/Uplink Datarate 5G Module –
5G: 3.4Gbps/200Mbps
LTE: 2Gbps/150Mbps
4G Module: 1.2 Gbps/150 MbpsPower Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 0.83 pounds | 375 grams -
Product Code
Description
EPX-LC-MFA
License Key to enable MediaFast with Content Hub & Docker (requires own disk drive to mount to the LCD Module).
Product Code Carrier Modems 4G Bands 3G Bands EXM-3LTEA-W Worldwide / LTE-A 3 B1, B2, B3, B4, B5, B7, B8 , B12,
B13, B20, B25, B26, B29, B30, B41
B1, B2, B3, B4, B5, B8 EXM-3LTEA-P Asia Pacific / LTE-A 3 B1, B3, B5, B7, B8, B18, B19,
B21, B28, B38, B39, B40, B41
B1, B5, B6, B8, B9, B19, B39 EXM-3LTEA-R America/FirstNet / LTE-A Pro 3 B1, B2, B3, B4, B5, B7, B8, B9,
B12, B13, B14, B18, B19, B20,
B26, B29, B30, B32, B41, B42,
B43, B46, B48, B66
B1, B2, B4, B5, B6, B8, B9, B19 EXM-3LTEA-K Global* / LTE-A Pro 3 B1, B2, B3, B4, B5, B7, B8, B9,
B12, B13, B18, B19, B20, B26,
B28, B29,B30, B32, B41, B42,
B43, B46, B48, B66
B1, B2, B4, B5, B6, B8, B9, B19 EXM-2GLTE-G Global /
CAT-18
2 B1, B3, B25(B2), B66(B4),
B26(B5/B18/B19), B7, B8,
B12(17), B13, B14 , B20, B28,
B29, B30, B32, B71, B38, B39,
B40, B41, B42, B43, B46, B48
B1, B2, B4, B5(B19), B8 -
Product Code Description EPX-M8 EPX Main chassis, supports 8 expansion modules EXM-LCDT Expansion Module with 1TB SSD, Features Content Hub, Docker Support and LCD Controls (Replaces existing LCD module) EXM-3LTEA-W Expansion Module with 3x LTE-A modems (CAT-6) EXM-3LTEA-P Expansion Module with 3x LTE-A modems (CAT-6) EXM-3LTEA-R Expansion Module with 3x LTE-A Pro modems (CAT-12) EXM-3LTEA-K Expansion Module with 3x LTE-A Pro modems (CAT-12) EXM-8C Expansion Module with 8x GE PoE ports EXM-4F Expansion Module with 4x SFP+ ports EXM-2GLTE-G Expansion Module with 2x LTEA (CAT-18) modems, compatible with EPX, SDX -
Q. Will the EPX be ready for 5G when it comes out?
A. Yes, we will develop new modules for new technologies (such as 5G) as they emerge.
Q. If I purchase EPX-EXM-LCDT, do I still need to add EPX-LC-MFA to enable this MediaFast/content hub?
A. The MediaFast/ContentHub feature is already included in EPX-EXM-LCDT, no need to purchase EPX-LC-MFA.
