Use Cases
Public Safety. First Responders.
Transportation. On – Board Deployments.
In – Vehicle Deployments & Fleet Tracking
Compatible With:
Topology, First Responder Connectivity to HQ
Designed for Mobility
The MAX Transit Mini has specialized features for vehicular deployments. Ignition sensing, which detects the ignition status of the vehicle, enables the device to turn on and off as the vehicle starts up and shuts down. It is also equipped with GPS, enabling you to track its movements. With InControl’s fleet management, you can review the route history of all your vehicles from any web browser.
Scalable Management
With a footprint of 4.1 x 4.3 inches, the Transit Mini can fit in just about any small space. It can be powered using Passive PoE, reducing the number of wires in the vehicle. Most importantly, the Transit Mini can be remotely managed by InControl cloud management^. This enables you to bulk push configurations and firmware updates, ensuring infinite scalability.
Get it all with PrimeCare
SpeedFusion
InControl2
Warranty
PrimeCare makes SpeedFusion networks easier to build. It bundles InControl, Warranty, SpeedFusion licence upgrades, FusionHub licenses into one subscription
Cellular WAN Interfaces Single LTE Modem Redundant SIM Slot Yes SpeedFusion Hot Failover Yes ^ SpeedFusion WAN Smoothing Yes ^ Number of PepVPN SpeedFusion Peers 5 ^ WAN Interface 1x 10/100M Ethernet Port ^ LAN Interface 3x 10/100M Ethernet Port
(1x WAN Port shared with LAN Interface)
(1x Serial Port shared with LAN Interface)
Load Balancing Yes Stateful Firewall Throughput # 100Mbps Recommended Users 60 LTE Modem Downlink/Uplink Data Rate:
LTE Modem 150Mbps/50Mbps
Wi-Fi Standard 802.11b/g/n Wi-Fi WAN^ and AP Antenna Connectors 2x SMA Cellular, 1x SMA GPS, 1x RP-SMA Wi-Fi Power Input Passive PoE Input (WAN Port, 12V – 28V DC) / Power + GPIO Power Consumption 12W (max.) Dimensions 4.1 x 4.3 x 1.2 inches |
105 x 110 x 30 mm
Weight 0.54 pound |
244 grams
Operating Temperature -40 ° – 149 °F
-40 ° – 65 °C
Humidity 15% – 95% (non-condensing) Certifications -FCC, CE, RoHS, IC
-EN 61000: Electromagnetic Compatibility
-EN61373: Rolling Stock
Warranty 1-Year Limited Warranty ^ Requires PrimeCare Subscription, complementary for the first year.
# Router Throughput and PepVPN/SpeedFusion Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments. Figures apply to the latest hardware revision. The throughput result is tested with DHCP/Static IP WAN.All specifications are subject to change without notice.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Complete VPN Solution PepVPN
Site-to-Site VPN
SpeedFusion Hot Failover^
256-bit AES Encryption
Pre-shared Key Authentication
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Security Stateful Firewall
DoS Prevention
Web Blocking
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Global Positioning System Integrated GPS
Device Location Map
Captive Portal Support Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
- MAX Transit Mini
- 1x GPS Antenna
- 1x WiFi Antenna
- 2x 2dBi 4G LTE Antennas
- 1x DC Cable (ACW-634)
Q. Is there a WAN activation license for the MAX Transit Mini?
WAN activation license is not required when covered under PrimeCare.
PrimeCare subscription comes complementary for the first year. Click HERE to discover more about PrimeCare.Q. How can I get the wiring diagram for the MAX Transit Mini?
Please check the diagram below for the wiring assignment for the Transit Mini. For additional details, you may refer to the MAX user manual section 24.7, titled “Ignition Sensing”.
Product Code Carrier Standard 4G Bands 3G Bands MAX-TST-MINI-LTE-E-T-PRM EU LTE Cat. 4 B1, B3, B5, B7, B8, B20,
B38, B40, B41
WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
MAX-TST-MINI-LTE-F-T-PRM America/FirstNet Ready LTE Cat. 4 B2, B4, B5, B12, B13,
B14, B66, B71WCDMA/HSPA+/DC-HSPA+:
B2, B4, B5
Product Code
Description
ACW-632
Power Supply Unit for MAX Transit Mini 12V2A
ACW-634 10ft Direct Wire DC Cable for MAX Transit Mini or BR1 Classic (HW3)
