SpeedFusion Engine
SpeedFusion Engine
You have a product that needs to get connected anytime, anywhere. The best solution is to
integrate unbreakable connectivity into your product. The SpeedFusion Engine helps you integrate SpeedFusion SD-WAN into your product, overcoming several key challenges:
SpeedFusion Engine Deployments
See and Manage Everything on InControl 2
Using Peplink’s InControl cloud-based management platform, you can view detailed connectivity, data usage, and even location information on all of your SpeedFusion Engines. In addition, InControl is also capable of
remotely accessing the SpeedFusion Engine’s web admin, as well as applying batch configurations and firmware updates to groups of devices.
Compare Models
ModelSpeedFusion EngineMAX BR1 SlimMAX BR1 Mini
Product CodeSFEBR1-SLIM-LTEBR1-MINI-LTE
Ethernet WAN Ports1 (FE, shared)%1 (FE)1 (FE)#
Ethernet LAN Ports1 (FE, shared)%1 (FE)1-2 (FE)
Embedded 4G LTE / 3G211
LTE Modem
Downlink/Uplink Datarate: 100Mbps/50Mbps
LTE-A Modem
Downlink/Uplink Datarate: 300Mbps/50Mbps
SIM Card SizeNano-SIM (4FF)Mini-SIM (2FF)Mini-SIM (2FF)
Redundant SIM Slotsspec_none
USB WAN Modem Portspec_nonespec_nonespec_none
Wi-Fi WAN 1spec_none #
Wi-Fi AP 1spec_none
Wi-Fi Standardspec_none802.11b/g/n 150Mbps802.11b/g/n 150Mbps
Transmit Power (2.4GHz)spec_none25dBm20dBm
Transmit Power (5GHz)spec_nonespec_nonespec_none
Recommended Users 21-601-601-60
Router Throughput 3100Mbps100Mbps100Mbps
Core Functionality
IP Passthrough
WAN as LAN
Web Blocking
Web Filtering BlacklistLiteLiteLite
VPN Functionality
PepVPN/SpeedFusion Hot Failover #
SpeedFusion WAN Smoothing spec_none
SpeedFusion Bandwidth Bonding spec_nonespec_none
Number of PepVPN SpeedFusion Peers22/5!2/5!
PepVPN/SpeedFusion Throughput (No Encryption)40Mbps40Mbps40Mbps
PepVPN/SpeedFusion Throughput (256-bit AES)20Mbps20Mbps20Mbps
Central Management
InControl Cloud Management
GPS Fleet Management
Hardware Features
EnclosureCompact, Indoor MetalIP50 Compact, Indoor MetalCompact, Indoor Metal
PoE Outputspec_nonespec_nonespec_none
Terminal Block Power Connector for
Mobile/Vehicular Deployment
Dimensions
(Width x Depth x Height)
2.95 x 3.25 x 1.65 inches
75 x 83 x 42 mm
3.8 x 4.8 x 1.1 inches
97 x 120 x 27 mm
4.1 x 4.3 x 1.2 inches
105 x 110 x 30 mm
Weight0.77 pound
350 grams
0.77 pounds
350 grams
0.54 pounds
244 grams
Operations
AC Adapterspec_nonespec_noneAC Input 100V-240V
DC Output 12V, 2A
Power InputTerminal Block 12V-24V DCMicro USB 5V 2ADC 12V – 28V 2A
Terminal BlockTerminal Block 12V-24V DCDC 12V-24V 2ADC 12V – 28V 2A
Power ConsumptionMax.: 13WMax.: 10W, Typical:
8.5W, Min.: 6W
Max.: 12W
Operating Temperature-40° – 149°F
-40° – 65°C
-40° – 149°F
-40° – 65°C
-40° – 149°F
-40° – 65°C
Certifications
FCC, CE, RoHS
Certifications – Motor Vehicle
E-Mark spec_none
Certifications – Rolling Stock
EN 61373:1999 IEC 61373:1999
Shock and Vibration Resistance
spec_none
EN 50155
Railway Applications - Electronic
Equipment used on Rolling Stock
spec_none
EN 61000
Electromagnetic Compatibility
spec_none ^
Warranty1-Year Limited Warranty
1 The frequency range for 802.11b/g/n Wi-Fi is 2412−2472 MHz.
2 Recommendation for sizing purposes only. No software restrictions applied.
3 Router Throughput is valid only for currently shipping devices running Firmware 7.0.1 or later. Router Throughput is based on Ethernet frame sizes of 1280 or 1518 bytes. Actual performance can vary across different networking environments.
^ Certifications pending.
* Optional PoE Activation Kit is required to activate 802.3af PoE Output.
! 2 PepVPN Peers are enabled by default. Can be increased to 5 Peers using license PVN-LC-05.
~ 2 PepVPN Peers are enabled by default. Can be increased to 5 Peers using license PVN-LC-05 or to 20 Peers using license MAX-HD-020-SPF.
% There is one Ethernet port, which performs as either WAN or LAN depending on how it’s defined in the firmware.
# Sold Separately.
SpeedFusion Engine Dimensions
Ordering Information
Product CodeCarrierEmbedded Modem(s)4G Bands/Frequencies (MHz)3G Bands/Frequencies (MHz)
SFE-DUO-LTE-US-ETUS/Americas^/CAT-32B2, B4, B5, B13, B17, B25WCDMA/HSPA+/DC-HSPA+: B1, B2, B4, B5, B8
EV-DO Rev.A: BC0, BC1, BC10
SFE-DUO-LTE-E-ETEurope/International/CAT-42B1, B3, B5, B7, B8, B20, B38, B40, B41WCDMA/HSPA+/DC-HSPA+: B1, B5, B8
SFE-DUO-LTEA-W-ETWorldwide/CAT-62B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8
SFE-DUO-LTEA-P-ETAsia Pacific/CAT-62B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41WCDMA/HSPA+/DC-HSPA+: B1, B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
^ Pending carrier certification in the US.
SpeedFusion Engine – Add-On Accessories
Product CodeDescription
SFE-DUO-ACW-KITSpeedFusion Engine Duo Demo Accessory Kit:
- ACW-414 x 4 (3m MMCX to SMA-M Magnetic Cellular Antenna Base)
- ACW-415 x 1 (5m MMCX Magnetic GPS Antenna)
- ACW-813 x 4 (2dBi Indoor Cellular Antenna)
- ACW-601 x 1 (12V 2A Power Supply)
- ACW-641 x 1 (SpeedFusion Engine Power Converter)
- ACW-422 x 1 (20cm USB cable)
SIM-BK8-4E-56VSIM Injector, 8x SIM cards capacity, 4x 10/100/1000 LAN ports, 56V DC
Find a Partner to Get Yours
Go!
Technical Specifications
4 IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
Download Datasheet
Go!
