SpeedFusion Engine Cam
DC Rugged anchor DC IP55 anchor
Unbreakable Video Streaming
The SpeedFusion Engine Cam (SFE Cam) uses SpeedFusion bandwidth bonding technology to combine the reliability and bandwidth of two cellular connections and Wi-Fi, giving you rock solid data link for live streaming*. With redundant SIM slots, the SFE Cam gives you a total of four SIM cards to select from. WAN Smoothing and FEC protect your video stream from the effects of packet loss.
*Cameras must have built-in streaming encoder with LAN or Wi-Fi connectivity.
Portable, Integrated
The SFE Cam is a self-contained unit with everything you need for unbreakable video streaming, including enclosed antennas. It is powered by Gold Mount or V-Mount and connected using RJ45 Ethernet LAN, making the set-up process fast and simple. With everything integrated into the IP camera, reporters have the speed and mobility needed to quickly capture live news, wherever it may occur.
Mobile Wireless Hub
With its Wi-Fi radio, the SFE Cam turns your IP camera into a portable hotspot with VPN access to headquarters. You can use this hotspot to connect laptops to begin post-processing, or even connect another IP camera for video streaming. Having a hotspot that travels with your IP camera gives you additional flexibility when and where you need it the most.
Centrally Manage Data Plans, Track Location
Use GPS to track the location of each IP camera, ensuring that the event is covered from all angles. For deployments involving multiple IP cameras and pooled SIM data, you can use the InControl central management platform to monitor SIM card data usage. If your network goes over the bandwidth limit on any SIM card or SIM pool, you will receive e-mail notifications.
Live News Coverage
In this deployment, the SpeedFusion Engine Cam (SFE Cam) streams the video to the datacenter using the combined bandwidth of two LTE connections, ensuring reliable and consistent connectivity. The video stream is received by a Balance router at the datacenter and forwarded to the media server for decoding and post-processing. Within the SpeedFusion connection, WAN Smoothing and FEC mitigate the effects of packet loss, ensuring smooth and consistent video streaming. Each cellular connection supports a redundant SIM card, so you can choose between four carriers.
The SFE Cam connects directly to your IP camera using the Gold Mount or V-Mount and the RJ45 Ethernet LAN port, enabling you to quickly set up and live stream from anywhere. The SFE Cam is equipped with a Wi-Fi radio which can either be used as another WAN for bandwidth bonding or as a hotspot to connect another IP camera.
sfe-cam-specsheet
Specifications
 SFE Cam
WAN Interface1x GE
2x Embedded LTE-A Modems with Redundant SIM Slots
LAN Interface1x GE
8-Pin Din USB
Wi-Fi Interface2x2 MIMO 802.11ac AP and WAN ^
Router Throughput400 Mbps
PepVPN/SpeedFusion Throughput
(No Encryption)
100 Mbps
(256-bit AES)
60 Mbps
LTE ModemDownlink/Uplink Datarate:
100 Mbps/ 50 Mbps
LTE-A ModemDownlink/Uplink Datarate:
300 Mbps/ 50 Mbps
Cellular and GPS
Antenna Connector
Internal Cellular, Wi-Fi and GPS Antennas
Power InputDC Jack 12V-24V DC
SFE-CAM-AB: Anton Bauer Gold Mount
SFE-CAM-VM: V-mount
Power Consumption18 W (max.)
Dimensions10.62 x 5.43 x 4.13 inches
270 x 138 x 105 mm
Weight4.41 pounds
2.0 kg
Operating Temperature-40 ° – 113 °F
-40 ° – 45 °C
CertificationsFCC, CE, RoHS, E-Mark
EN 55032: 2015 - Electromagnetic Compatibility of
Multimedia Equipment
EN 61000, EN55024, EN62311, EN60950
Warranty1-Year Limited Warranty
^ Simultaneous Wi-Fi WAN and AP can only function on one of the spectrums (either 2.4 or 5GHz)
Ordering Information – SFE CAM
Product CodeCarrierModems4G Bands3G Bands
SFE-CAM-AB-LTEA-WWorldwide2B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20,
B25, B26, B29, B30, B41
WCDMA/HSPA+/DC-HSPA+:
B1, B2, B3, B4, B5, B8
SFE-CAM-AB-LTEA-PAsia Pacific2B1, B3, B5, B7, B8, B18, B19, B21, B28,
B38, B39, B40, B41
WCDMA/HSPA+/DC-HSPA+: B1, B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
SFE-CAM-VM-LTEA-WWorldwide2B1, B2, B3, B4, B5, B7, B8, B12, B13, B20,
B1,B2, B3, B4, B5, B8
SFE-CAM-VM-LTEA-PAsia Pacific2B1, B3, B5, B7, B8, B18, B19, B21, B28,
B38, B39, B40, B41
UMTS: B6
TD-SCDMA: B39
Technical Specifications
* IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
Download Datasheet
Go!
