Portable, Integrated
Mobile Wireless Hub
With its Wi-Fi radio, the SFE Cam turns your IP camera into a portable hotspot with VPN access to headquarters. You can use this hotspot to connect laptops to begin post-processing, or even connect another IP camera for video streaming. Having a hotspot that travels with your IP camera gives you additional flexibility when and where you need it the most.
Centrally Manage Data Plans, Track Location
Use GPS to track the location of each IP camera, ensuring that the event is covered from all angles. For deployments involving multiple IP cameras and pooled SIM data, you can use the InControl central management platform to monitor SIM card data usage. If your network goes over the bandwidth limit on any SIM card or SIM pool, you will receive e-mail notifications.
SpeedFusion Engine CAM solution explained By JVC PRO USA
John Basile, JVC product specialist, provides an overview of the SFE-CAM
Use Case. Live News Coverage
In this deployment, the SpeedFusion Engine Cam (SFE Cam) streams the video to the datacenter using the combined bandwidth of two LTE connections, ensuring reliable and consistent connectivity. The video stream is received by a Balance router at the datacenter and forwarded to the media server for decoding and post-processing. Within the SpeedFusion connection, WAN Smoothing and FEC mitigate the effects of packet loss, ensuring smooth and consistent video streaming. Each cellular connection supports a redundant SIM card, so you can choose between four carriers.
The SFE Cam connects directly to your IP camera using the Gold Mount or V-Mount and the RJ45 Ethernet LAN port, enabling you to quickly set up and live stream from anywhere. The SFE Cam is equipped with a Wi-Fi radio which can either be used as another WAN for bandwidth bonding or as a hotspot to connect another IP camera.
WAN Interface 1x GE
2x Embedded LTE-A Modems with Redundant SIM Slots
LAN Interface 1x GE
8-Pin Din USB
Wi-Fi Interface 2×2 MIMO 802.11ac AP and WAN * Router Throughput 400 Mbps PepVPN/SpeedFusion Throughput
(No Encryption) | (256-bit AES)
100 Mbps | 60 Mbps LTE Modem Downlink/Uplink Datarate:
100 Mbps/ 50 Mbps
LTE-A Modem Downlink/Uplink Datarate:
300 Mbps/ 50 Mbps
Cellular and GPS
Antenna Connector
Internal Cellular, Wi-Fi and GPS Antennas Power Input DC Jack 12V-24V DC
SFE-CAM-AB: Anton Bauer Gold Mount
SFE-CAM-VM: V-mount
Power Consumption 18 W (max.) Dimensions 10.62 x 5.43 x 4.13 inches |
270 x 138 x 105 mm
Weight 4.41 pounds |
2.0 kg
Operating Temperature -40 ° – 113 °F |
-40 ° – 45 °C
Humidity 15% – 95% (non-condensing) Certifications -FCC, CE, RoHS, E-Mark
-EN 55032: 2015 – Electromagnetic -Compatibility of
Multimedia Equipment
EN 61000, EN55024, EN62311, EN60950
Warranty 1-Year Limited Warranty *Simultaneous Wi-Fi WAN and AP can only function on one of the spectrums (either 2.4 or 5GHz)
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
Global Positioning System Integrated GPS
Device Location Map
Location Tracking Data
GPS eXchange Format (GPX)
Up to Seven Days
Complete VPN Solution PepVPN
SpeedFusion
Site-to-Site VPN
SpeedFusion Hot Failover
SpeedFusion Bandwidth Bonding
SpeedFusion WAN Smoothing
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
X.509 Certificate Support
PPTP VPN Server
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Security Stateful Firewall
DoS Prevention
Web Blocking
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Social Wi-Fi Hotspot support
External Captive Portal support
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Product Code Carrier Embedded Modems 4G Bands 3G Bands SFE-CAM-AB-LTEA-W Worldwide 2 B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20,
B25, B26, B29, B30, B41
WCDMA/HSPA+/DC-HSPA+:
B1, B2, B3, B4, B5, B8
SFE-CAM-AB-LTEA-P Asia Pacific 2 B1, B3, B5, B7, B8, B18, B19, B21, B28,
B38, B39, B40, B41
WCDMA/HSPA+/DC-HSPA+: B1, B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
SFE-CAM-VM-LTEA-W Worldwide 2 B1, B2, B3, B4, B5, B7, B8, B12, B13, B20,
B1,B2, B3, B4, B5, B8
SFE-CAM-VM-LTEA-P Asia Pacific 2 B1, B3, B5, B7, B8, B18, B19, B21, B28,
B38, B39, B40, B41
UMTS: B6
TD-SCDMA: B39
- SpeedFusion Engine CAM
- USB-to-Camera Cable (ACW-418)
- 1x 12V2A Power Supply (ACW-601)
