Products
Solutions
Technology
Support
Buy
Company
Products
Enterprise Routers
Balance
SDX
Enterprise Mobility
Dome
MBX
PDX
Mobile Routers
BR
Transit
Enterprise Branch Routers
B One
Cellular Modems & Adapters
MAX Adapter
POTS Adapter
Wi-Fi & PoE Switch
Antennas & Accessories
Services
Software
Care Plans
eSIM Data Plans
SpeedFusion Connect
Solutions
SpeedFusion
IoT
Private 5G & LTE
Starlink
Public Safety
Enterprise Networks
Service Providers
Transportation
Resources and Tutorials
Case Studies
Brochures and Whitepapers
User Testimonials
Training
How-To Handbook
What is 5G?
SD-WAN
About SpeedFusion
Cellular Bonding
Virtual WAN
Private 5G Networks
eSIM Routers
Peplink Security
InTouch Remote Management
Peplink Support
Downloads & Manuals
Community
Care Plans
InControl Login
Training Portal Login
Partner Pavilion Login
Peplink App Download
Hardware
E-Tailers
Certified Partners
Partner Programs
Peplink eStore
About Us
Newsroom
Career
Privacy Policy
No Results Found
Please try searching with different keywords.
View full search results
Compare Switch models
Compare other series?
Check
Routers
and
Access Points
8 PoE 10G Switch
24 PoE 2.5G Switch
24 PoE 2.5G Switch Rugged
48 PoE 2.5G Switch
SD Switch 8-Port Rugged
SD Switch 16-Port Rugged
SD Switch 24-Port Enterprise
SD Switch 24-Port Rugged
SD Switch 48-Port Enterprise
8 PoE 10G Switch
24 PoE 2.5G Switch
48 PoE 2.5G Switch
8 PoE 10G Switch
24 PoE 2.5G Switch
48 PoE 2.5G Switch
Tech Specs PDF
Learn more
Tech Specs PDF
Learn more
Tech Specs PDF
Learn more
Specifications
Show differences only
No differences
RJ45 interface
8x 10GE (802.3bt Type 4 PoE++)
RJ45 interface
16x 1GE (802.3at PoE+)
8x 2.5GE (802.3at PoE+)
RJ45 interface
32x 1GE (802.3at PoE+)
16x 2.5GE (802.3at PoE+)
SFP / SFP+ interface
4x 10G SFP+
4x 10G SFP+
4x 10G SFP+
VLAN Groups
Yes
VLAN Groups
Yes
VLAN Groups
Yes
Switch Capacity
240 Gbps
Switch Capacity
152 Gbps
Switch Capacity
224 Gbps
Maximum Packet Forwarding Rate
179 Mpps
216 Mpps
318 Mpps
MAC Address Table
32000
MAC Address Table
16000
MAC Address Table
32000
Inter-VLAN Routing
Yes
Inter-VLAN Routing
Yes
Inter-VLAN Routing
Yes
Power Supply Unit
1x Internal PSU (900W)
Power Supply Unit
1x Internal PSU (480W)
Power Supply Unit
Power Input
1x 100V – 240V AC
Power Input
1x 100V – 240V AC
Power Input
1x 100V – 240V AC
Power Consumption
53W (System)
Power Consumption
38W (System)
Power Consumption
64W (System)
Total PoE Power Budget
720W
410W
740W
Dimensions in inches (D x W x H)
9.1 x 13.0 x 1.8 inches
10.3 x 17.3 x 1.8 inches
12.2 x 17.3 x 1.8 inches
Dimensions in mm (D x W x H)
230 x 330 x 44 mm
260 x 440 x 45 mm
310 x 440 x 45 mm
Weight (Pound)
6.4 pounds
Weight (Pound)
9.0 pounds
Weight (Pound)
10.8 pounds
Weight (Kilogram)
2.9 kg
Weight (Kilogram)
4.1 kg
Weight (Kilogram)
4.9 kg
Operating Temperature
32°F – 122°F
0°C – 50°C
32°F – 122°F
0°C – 50°C
32°F – 122°F
0°C – 50°C
Humidity
15% – 95% (non-condensing)
Humidity
Humidity
Warranty
1-Year Limited Warranty
Warranty
Warranty
