Scalable LAN Management
Effortlessly manage hundreds of SD-Switches and Peplink Routers. The InControl 2 cloud management platform makes it possible.
Monitor
Port status, connectivity, firmware version.
Troubleshoot
See all clients, search by MAC address.
Configure
Centralize VLAN, firmware, and configurations.
Essential Building Block for Every Network
High Capacity Uplinks
PoE+ Output
Out-Of-Band Management
Uninterrupted Power
The SD-Switch has redundant power supplies. So even if one PSU stops working, the SD-Switch will keep connecting your network.
No Connection? No Problem
With Out-Of-Band management, simply plug in a USB dongle to remotely access your SD-Switch. Remotely access the web admin using InControl 2.
