SD Switch 24-Port Rugged
Industrial Grade 24-Port SD Switch for Rugged Environment #2
Simplified LAN Management
Meet Peplink SD Switches Rugged. Benefit from multiple redundancy technologies for the always-on uptime your network needs.
Locate a Reseller
No more Command Lines
Use InControl 2 cloud management to remotely monitor, troubleshoot, and configure your network.
Monitor
Port status, connectivity, firmware version.
Troubleshoot
See all clients, search by MAC address.
Configure
Centralize VLAN, firmware, and configurations.
Powerful Robust Performance
High Capacity Uplinks
PoE+ Output
Out-Of-Band Management
Fanless Design. Ready for Any Environment
The SD Switch Rugged can handle -40°F (-40°C) to 149°F (65°C). The fanless design enables it to function in high-particle environments.
    LAN Interface24x 802.3at (PoE+) GE Ports,
    2x SFP+ Ports
    VLAN GroupsYes
    Fiber Module2x 10 Gbps
    Switch Capacity88 Gbps
    Max. Packet
    Forwarding Rate
    66 Mpps
    MAC Address Table32,000
    Inter-VLAN RoutingYes
    AC AdaptorAC Input 100V-240V
    DC Output 54V*
    Power InputRedundant DC Power DIN: 54V
    Terminal Block: 12V - 54V DC
    Power
    Consumption
    50W System,
    120W PoE+ Power Budget
    (supports up to 250W * )
    Dimensions
    (D x W x H)
    10.5 x 19.1 x 1.7 inches |
    265 x 485 x 45mm
    Weight11.3 pounds |
    5.14 kg
    Operating Temperature-40° – 149°F |
    -40° – 65°C
    CertificationFCC, CE, RoHS, IC #
    EN 61000: Electromagnetic Compatibility #
    Warranty1-Year Limited Warranty
    * The bundled PSU provides 120W of PoE power budget. If you require 250W of power budget, please add 180W PSU (ACW-630) to your device.
    # Pending certification.
  • Product Code
    Description
    PSW-24-250W-RUG
           PoE enabled (delivers up to 250W) Gigabit (24 ports) and SFP (2 ports) switch with a fanless design for industrial environments.
  • Product Code Description
    SVL-514 1-Year EssentialCare for SD Switch 24-Port Rugged
    SVL-702 2-Year EssentialCare for SD Switch 24-Port Rugged
    ICS-V03-1Y 1-Year InControl 2 Subscription for SD Switch
    ICS-V03-2Y 2-Year InControl 2 Subscription for SD Switch
    ECP-E-1Y EssentialCare+ E (1-Year)
    ECP-E-2Y EssentialCare+ E (2-Year)
    ECP-E-4Y EssentialCare+ E (4-Year)
    • SD Switch 24-Port Rugged
    • 1x PSU 180W (ACW-630)
    • Screw set for rack mounting
    • 2pin Terminal Block Connector
    • 4pin Terminal Block Connector (Power supply)
    • Rubber Foot Pad set
