SD Switch 24-Port Enterprise
Enterprise-Grade PoE Switch with Cloud Intelligence
Presenting highly scalable Peplink enterprise switches that provide carrier-grade reliability, LAN management and out-of-band management.
Scalable LAN Management
Effortlessly manage hundreds of SD-Switches and Peplink Routers. The InControl 2 cloud management platform makes it possible.
Monitor
Port status, connectivity, firmware version.
Troubleshoot
See all clients, search by MAC address.
Configure
Centralize VLAN, firmware, and configurations.
Essential Building Block for Every Network
High Capacity Uplinks
PoE+ Output
Out-Of-Band Management
Uninterrupted Power
The SD-Switch Enterprise has redundant power supplies. So even if one PSU stops working, the SD-Switch Enterprise will keep connecting your network.
No Connection? No Problem
With Out-Of-Band management, simply plug in a USB dongle to remotely access your SD-Switch Enterprise. Remotely access the web admin using InControl 2.
Dual AC Power Input 24-Port SD Switch w. 850W Power Budget #6
    LAN Interface24x 802.3at PoE GE Ports,
    2x SFP+ Ports
    VLAN GroupsYes
    Fiber Module2x 10 Gbps
    Switch Capacity88 Gbps
    Max. Packet Forwarding Rate66 Mpps
    MAC Address Table32,000
    Inter-VLAN RoutingYes
    Power Input2x 100V – 240V AC Input,
    With Power Redundancy
    Integrated Power Source850W: 3x Redundant PSU
    Power Consumption
    50W System,
    850W PoE+ Power Budget
    Dimensions
    (D x W x H)
    10.5 x 19.1 x 1.7 inches
    265 x 485 x 45mm
    Weight13.7 pounds | 6.2 kg
    Operating Temperature32° – 104°F | 0° – 40°C
    Certification FCC, CE, RoHS, IC
    EN 61000: Electromagnetic Compatibility
    Warranty1-Year Limited Warranty
    Product Code
    Description
    PSW-24-850W
                PoE enabled (delivers up to 850W) Gigabit (24 ports) and SFP+ (2 ports) switch with redundant power inputs and 2x power supplies.
  • Product Code Description
    SVL-426 1-Year EssentialCare for SD Switch 24-Port Enterprise
    SVL-524 2-Year EssentialCare for SD Switch 24-Port Enterprise
    ICS-V03-1Y 1-Year InControl 2 Subscription for SD Switch
    ICS-V03-2Y 2-Year InControl 2 Subscription for SD Switch
    ECP-E-1Y EssentialCare+ E (1-Year)
    ECP-E-2Y EssentialCare+ E (2-Year)
    ECP-E-4Y EssentialCare+ E (4-Year)
    • SD Switch 24-Port Enterprise
    • 2x Power Cord (ACW-614)
    • 2x L-Mount for switch back side
    • Screw set for rack mounting
    • Rubber Foot Pad set
