Mobility 82G
Built for 5G
Omni-directional 8×8 MIMO mobile antenna for the best performance.
Ultra Wide Bandwidth
Wide frequency range (600-6000MHz) supporting LTE and 5G connectivity in any location.
Robust Design
IP67 rated, low profile and durable housing.
Built for 5G
Robust Design
Easy Installation
Surface, panel installation for various applications.
Flexible Applications
- Public Safety & Mission Critical Connectivity
- Mobile Healthcare
- Transportation Connectivity
Actual Sizes
Product Code Description ANT-MB-82G-S-W-6 8xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, SMA (Cellular, GPS), RP-SMA (Wi-Fi), White, 6.5 ft / 2m ANT-MB-82G-Q-W-6 8xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, QMA (Cellular, GPS), RP-SMA (Wi-Fi), White, 6.5 ft / 2m -
Product Code Description ACW-667 Surface mount ACW-668 Surface mount with magnets -
- 1x MB-82G
- Long and short thread
- Double sided 3M adhesive pad (Diameter: 15.2” / 386 mm)(Thickness: 0.08” / 2 mm)
