MAX Transit Mini
DC Rugged anchor DC IP55 anchor
Band 71 and FirstNet Ready
Band 71 operates at a 600MHz frequency that travels twice as far and works four times better in buildings than conventional LTE bands. This means Band 71 provides better coverage in remote areas as well as indoors. FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The Transit Mini supports both bands, providing additional coverage as the situation demands.
Made for Mobility
The MAX Transit Mini has specialized features for vehicular deployments. Ignition sensing, which detects the ignition status of the vehicle, enables the device to turn on and off as the vehicle starts up and shuts down. It is also equipped with GPS, enabling you to track its movements. With InControl’s fleet management, you can review the route history of all your vehicles from any web browser.
Scalable Management
With a footprint of 4.1 x 4.3 inches, the Transit Mini can fit in just about any small space. It can be powered using Passive PoE, reducing the number of wires in the vehicle. Most importantly, the Transit Mini can be remotely managed by InControl cloud management^. This enables you to bulk push configurations and firmware updates, ensuring infinite scalability.
^ Requires PrimeCare Subscription, complementary for the first year.
On-Board Connectivity and Entertainment
The MAX Transit Mini connects using LTE, supporting band 71 for improved range and signal penetration. This means the Transit Mini will stay connected even in remote areas where other bands drop off.
The Transit Mini’s can be powered and connected using passive PoE input. To prevent battery drain, the MAX Transit Mini features Ignition Sensing, which senses the ignition status of the vehicle and turns the router on or off accordingly. For fleets of multiple vehicles, the Transit Mini is equipped with GPS.
First Responder Connectivity to HQ
Connect to headquarters using FirstNet, with failover to Band 71 as needed. 2-way radios to communicate between multiple remote sites. Use the built-in GPS to see its location in real-time and use InControl central management^ to remotely configure any connected router.
The device itself is easy to install: it can be powered using PoE or Micro-Fit 3.0 2×2 connector, providing installation versatility.
Peplink PrimeCare
primecare
max-transit-mini-specs
Specifications
 MAX Transit Mini
Cellular WAN InterfacesSingle LTE Modem
Redundant SIM Slot
SpeedFusion Hot Failover ^
SpeedFusion WAN Smoothing ^
Number of PepVPN SpeedFusion Peers5 ^
WAN Interface1x 10/100M Ethernet Port^
LAN Interface3x 10/100M Ethernet Port
(1x WAN Port shared with LAN Interface)
(1x Serial Port shared with LAN Interface)
Load Balancing
Stateful Firewall Throughput100Mbps
Recommended Users60
LTE ModemDownlink/Uplink Datarate:
LTE Modem 150Mbps/50Mbps
Wi-Fi Standard802.11b/g/n Wi-Fi WAN^ and AP
Antenna Connectors2x SMA Cellular, 1x SMA GPS, 1x RP-SMA Wi-Fi
Power InputPassive PoE Input (WAN Port, 12V – 28V DC) / Power + GPIO
Power Consumption12W (max.)
Dimensions4.1 x 4.3 x 1.2 inches
105 x 110 x 30 mm
Weight0.54 pound
244 grams
Operating Temperature-40 ° – 149 °F
-40 ° – 65 °C
CertificationsFCC, CE, RoHS, IC
EN 61000: Electromagnetic Compatibility
EN61373: Rolling Stock
Warranty1-Year Limited Warranty
MAX Transit Mini – Ordering Information
Product CodeCarrierStandard4G Bands3G Bands
MAX-TST-MINI-LTE-E-T-PRMEULTE Cat. 4B1, B3, B5, B7, B8, B20,
B38, B40, B41
WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8
MAX-TST-MINI-LTE-F-T-PRMAmerica/FirstNet ReadyLTE Cat. 4B2, B4, B5, B12, B13,
B14, B66, B71
B2, B4, B5
MAX Transit Mini – Accessories
Product CodeDescription
ACW-63212V2A 4-Pin Power Supply for Transit Mini
Technical Specifications
Download Datasheet
Go!
